Results 1 to 20 of 20
Thread: Intex Ultra Frame Round 26' Build
    Jul 2012
    SE Minnesota
    137
    Marked out the area for the new 26' Ultra Frame, you can see the pink spray paint in the grass. The area already dug out was where the old 18' Easy Set was.
    Getting started on the digging.
    After another day of digging.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Intex Ultra Frame Round 26' Build
    Alright! Congrats on the upgrade! Gonna be a good summer!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,490
    How are you poor shoulders and back???? You have done a great bit of work already! It really looks like you are doing it the correct way as well! NICE!
    Kim
    Jul 2012
    SE Minnesota
    137
    It's actually been pretty easy so far, taking it slow and steady, the pool doesn't really need to be up for another 6 weeks. The hardest part that makes everything hurt is yet to come which is skimming the last inch or two to make the 615 sq ft level with the lowest point. And that kick sod cutter for the grass on the left side of the photos. I hoped I would never see that thing again after last year but I guess that isn't gonna happen.
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Quote Originally Posted by krazykrames View Post
    You are making me flashback a few years when I did ours... Was sooooo not a good time
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Jul 2012
    SE Minnesota
    137
    Stump removed.
    All the sod removed. This pool is huge.
    Mother nature had something to say about my progress, 10" worth.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Yikes! It's a little late for that nonsense. And I like snow.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    We had a month of rain when we tried to get the ground prepped for our install. I'd get one or two pavers level and have to put everything away because it would rain again. Bought the pool the end of May and it didn't go up until July 4th. Hope that white stuff melts soon for you!
    Jul 2012
    Tallahassee, FL
    30,490
    Great progress! Who got the stump out and how???? I bet there were some adult words said during that job!
    Kim
    Jul 2012
    SE Minnesota
    137
    Well the snow has pretty much melted over the last few days, everything is a pretty soggy mess though. We dug the stump out by hand, it took a while. It wasn't as bad as it looks though, the roots only went down a few feet and just spread out horizontally. Fortunately it was in a location that had to be dug down anyway so there was no filling back in a hole.
    Jul 2012
    SE Minnesota
    137
    Dirt removal is done!
    Low side was only 1 - 2 inches, just enough to remove the sod.
    High side was a different story, the highest point is 19"!
    Many thanks to TFP for the water level idea. Mine is a little more simple, one end is stationary and tied to the fence. I set a low point and put the other end of the level on that and just made a pencil mark on the post. As long as every point in the pool area matched the original mark everything is level. It really isn't necessary to nail a yard stick to the post.
    One important thing I noticed is that the water level can change with temperature. One morning at 35 compared to a sunny afternoon at 65 the water level dropped about 6" and the next cold morning it was back to where I started the first morning. I think the hose expanded just a TINY bit when warm which caused this. It wasn't a problem, I just checked into my original low point about every half hour and made a new mark on the post if I needed.
    Jul 2012
    SE Minnesota
    137
    Brought in the sand, ended up being about 2" deep. I used the 2x4 with a level method to really get the sand leveled out. I checked it with the water level and it actually got the sand very close.
    On to tamping and leveling again and tamping again. Also I placed the pavers. I put together the top ring to get their placement as close as possible.
    I put the pavers out a few inches from center to compensate when the legs get pushed out of vertical when the pool is full of water. I also have the pavers below the level of the sand about a half inch, I didn't want them to ever come in contact with the liner.
    Jul 2012
    SE Minnesota
    137
    I laid the tarp down and put the pool up! I slid the tarp behind the legs so I could see the pavers and got the pool centered, then put the tarp back under the legs.
    Here's a picture for reference, this pool really is huge!
    Jul 2012
    SE Minnesota
    137
    Found a few good install videos for Intex Ultra frames.
    Installing an Intex Round Metal Frame Pool PROFESSIONALLY | Above Ground Pros
    Intex Round Metal Frame Installation Tutorial Part 2
    Found it interesting that they put pavers under the legs after the pool was up.
    Jul 2012
    SE Minnesota
    137
    I checked the legs with a level as the pool was filling to keep them straight. Once it's half full you really can't move them much anymore. It is important to put the pavers out a few inches from being centered because the legs will move out a little.
    I rigged up a hose to the filter so I could get it running while I waited for the water to reach the outlets. Also have a sock with 4# of CYA hanging in front of the return.
    Ended up taking 34 hours to fill up.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Yay! Looks great!
    Jun 2013
    Cerritos, CA
    576
    Wooohoo!! I remember filling up mine after all the work... Best feeling was getting in it
    Christina
    Jul 2012
    SE Minnesota
    137
    Thanks! Can't wait to get in, probably won't be till the first of June before it's warm enough.
    I have a feeling this pool will be a never ending project, already on my wish list is a retaining wall on the dug in side, pea gravel or something around the pool, thru wall skimmer, upgraded filter and pump, solar heating, deck of some kind and I'm sure I'll think of other things
    Jul 2012
    SE Minnesota
    137
    For anyone reading this and trying to figure out how to best put one of these up there is one thing I would try different.
    I would try putting the pavers in after the pool is constructed, like how they did in the video I linked in post #14. The reason I say this is that it was really hard to get the pool centered on pavers that were already in place. Currently some of the legs are close to the middle of the paver but there are many that are slightly sliding off a side or back of the paver. I did keep them level as the pool was filling but they do push out a few inches when full. I put half pavers next to the inplace ones where it looks like the legs are slightly sliding off so it should be fine. In the fall when the pool is half drained I plan on re-centering the pavers with the legs.
  20. Back To Top    #20
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I used the top rail as a guide for.my pavers, adjust by about 3" to allow for the movement when filling. Our ground is much firmer than that in the video, have the pool in the way would have made it difficult to manuver. (It was easy to the railing back and forth.) I only had one paver close to the edge. I think it was the first one I did. The video was nicely done, but most of us don't have more than 2 people putting up the pool, that guy had a whole crew, lol.
