Thread: SLAM Q's
    May 2014
    Las Vegas NV
    45
    SLAM Q's
    Hello,
    I just drained/refilled my entire pool and added Cyanuric Acid using the sock method and am ready to slam but have a few questions.
    1. Can you SLAM when water temp at 60 degrees.
    2. Do I need to SLAM with fresh water that's never been above 60 degrees in the week since it's been filed? Had pucks in the whole time waiting for Cyanuric Acid to register.
    3. Can I SLAM while aerating?
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: SLAM Q's
    Yes you can SLAM at 60 degrees. Can you provide a full set of test results so we can advise you better? Don't aerate so much that your pH goes above 7.2-7.4.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: SLAM Q's
    Quote Originally Posted by badgerwooz View Post
    Hello,
    1. Can you SLAM when water temp at 60 degrees. Yes.
    2. Do I need to SLAM with fresh water that's never been above 60 degrees in the week since it's been filed? Did you have algae before? If so, yes. If no, no. Had pucks in the whole time waiting for Cyanuric Acid to register.
    3. Can I SLAM while aerating? Better do do one thing at a time. You can't trust the pH readings when FC is above 10, so aerating as part of the process to lower TA won't work anyway because you'll be working blind.
