Thread: Solar and Acid Startup
    Sep 2015
    Orlando, FL
    33
    Hey guys, Began an acid startup yesterday for my new pool. pH is too low to read.
    How soon can I startup my solar without damaging the solar or marcite? I can't imagine it'd hurt the aggregate finish if used only briefly right?
    Asking because the solar guys are coming tomorrow to complete the install and get up and running.
    Thx
    38,548
    Re: Solar and Acid Startup
    I am not aware of any reason that you could not run the solar right away. If the rest of the pool equipment and plumbing can be run with the pH you are running for startup, I think the solar should also be fine.
    Apr 2013
    Sacramento, CA
    2,769
    I'd agree with Jason.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Are you sure they are circulating your pool during the Acid start up?
    Essential Links:
    Sep 2015
    Orlando, FL
    33
    Main pump is running full flow 24/7, not circulating through the floor cleaners yet just eyeball returns.
    Thanks for your replies.
