Thread: Booster Pump Replacement
    Jun 2013
    Plano, TX
    12
    Good Afternoon!
    The original booster pump (Hayward 5060) that powers my cleaner (Polaris 280) has finally expired. It was installed with the pool build in 2004. I see a Hayward 6060 for about $250 and a Polaris PB4-60 for $240, both at Amazon. Does anyone have any experience / opinion on which of those two might be better?
    I stopped at Leslie's to check yesterday, and all they carry is the Polaris for $340!
    I watched a couple of on-line videos regarding replacement, and they all indicate the use of soft connections that look similar to water supply lines used on toilets. My current connections are with 3/4" (I think) PVC pipe - how difficult would it be to convert the PVC to soft connections, keeping in mind that I'm not very handy? Last year, I cut out an old waterfall pump and installed a new pump, including plumbing new PVC pipe.
    I'm a bit leery of trying the booster pump installation - Leslie's is running a special for $99 installation for any equipment. But they exempt the booster pump and the install cost for that is about $175 with all associated costs included. The store manager doesn't know why, but he assumes it is a more complex installation.
    Thanks!
    33,000 gal, IG/plaster, spa/waterfall combo plus waterfall
    Hayward DE filter 72 ft, 2.0 HP Hayward Tristar pump
    1.5 HP Hayward Northstar pump for waterfall, SWG,
    Polaris 280 cleaner
    Nine 1/2 foot deep end with diving board
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Booster Pump Replacement
    That doesn't seem right!
    Essential Links:
