Results 1 to 7 of 7
Thread: How low can pH go?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    How low can pH go?
    What's an acceptable level to have pH for a short amount of time? I'm lowering pH to lower my TA. I'm getting the pH down to between 7.0-7.2 and then raising with both my water feature and salt system. Is it ok that my pool sits at that pH range for a day or so while I let it naturally rise up when I run my pump at night..... or should I be running my pump all day to raise my pH faster?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: How low can pH go?
    Do you have metal in the pool (hand rails, heaters, etc)? If so, try to only go to 7.2. It's ok to sit at 7.2 for a while, just don't go lower.
    Matt
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    No metal, only natural stone in some areas
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Matt is right, it's best to shoot low for 7.2. What do your other parameters look like normally? If you don't have some hardness in the water, the lower you go, the more threatening it is. That said, don't panic if you overshoot to 7.0 at some point.
    Essential Links:
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Quote Originally Posted by Patrick_B View Post
    I haven't done a hardness test lately but I can guarantee that the water is high in calcium. It always is here in the desert.
    30,431
    Good morning! Put your city and state in your sig so we know what climate you're in.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Done, I added it to my profile
