Results 1 to 9 of 9
Thread: Help with a nasty plaster stain...
    May 2012
    Austin, TX
    140
    I can't get rid of this stain by shocking the pool. Any suggestions on what to do?
    ~23,500 Gallon In-Ground Plaster Pool, Intelliflo VS+ Pump, Hayward 4820 DE Filter, IntelliChlor IC40 SWG
    Jan 2012
    'burbs of Augusta, Georgia
    7,351
    Re: Help with a nasty plaster stain...
    Two tests: Hold a chlorine puck against the stain and see if it disappears. And grab some cheap Vitamin C tablets and try them on the stain.
    If the puck works-its organic. If the Vit C works its a metal stain.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    I've got one of those too. Can't brush it off, elevated chlorine didn't do much, but it's only been a day. If it doesn't improve in a few days or so I might lay a puck on it for 15 minutes and see what that does. If that doesn't work I'm planning on diving to it when it warms up and scrubbing.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2012
    Austin, TX
    140
    Quote Originally Posted by Mr Bruce View Post
    What are you going to scrub it with?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Quote Originally Posted by Drockfresh View Post
    The same brush head that goes on the pole. I'm actually bored and decided to go ahead and try the puck. It looks exactly like yours and is raised, like caked mud or something.
    edit: Puck got it 80%. I'm going to let time and whatever chlorine is in the pool finish, I was uncomfortable leaving it on the floor any longer.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    If a puck helps then you can raise your FC up to SLAM level for your CYA and brush it a few times a day or more and it should go away in a week or two. Chlorine CYA Chart
    Aug 2014
    Northern IL
    4,615
    Drockfresh (OP), let us know what you find!
    Jul 2011
    Arizona & California
    803
    It doesn't look like "black" algae, so I think the black stain is most likely from the rebar "rusting" below the plaster surface (gunite) and then bleeding to the surface. To fix requires chipping out the plaster and gunite down to the rebar and removing and treating properly so that it doesn't rust again. Chlorine tabs, acid, and other treatments won't stop this type of problem because it is all the way through the plaster coat.
    May 2012
    Austin, TX
    140
    Quote Originally Posted by onBalance View Post
    I bet that's what it is because the pool has had other structural issues. I just rebuilt the bond beam after it crumbled into the pool. Then I had to knock out and replace the deck. spent too much on that project- you wouldn't believe it.
    If there is ever money to replaster I'll take care of this. For now will have to let it be. There is no way I'm draining the pool to deal with this.
