Results 1 to 8 of 8
Thread: Is there any sense in a one-time spring heating?
    Jul 2012
    Mountain House, CA
    62
    I have an in-ground pool with spa and gas heater and an automatic cover, about 10k gallons.
    In the spring, the weather warms up, then it seems to take the water forever to 'catch up' to the current weather.
    Is there any merit to the idea that a one-time heating of the pool could be beneficial in an ongoing way, if the heat was retained due to warmer weather?
    Or am I kidding myself, and the water would be back to the same temp it would have been within a day or two?
    10k gal IG w/ salt system, spa, gas heater, and auto cover.
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    Re: Is there any sense in a one-time spring heating?
    I suspect that it will drop down again as long as the night temps drop below your pool temp. I have nothing to back this idea up with though... If you do it, keep track and let us know how it works. I recall reading that if your daytime temps are 90, and nighttime 70, your water will hover about 80. Of course the autocover will help but how much... I dunno?
    Your signature lines appears to need some updating too
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    What are your night time temps? THAT will be the biggest factor.
    Where are you located?
    Kim
    Jul 2012
    Mountain House, CA
    62
    Quote Originally Posted by kimkats View Post
    Kim
    I'm in the central valley CA. Nighttime temps are still dipping into the 50's, so maybe it would be a waste. Hitting 75 during the day which makes it seem summer like!
    Jul 2012
    Tallahassee, FL
    30,510
    It is your wallet so............if you want to try it do so. With your auto cover it MIGHT hold in the heat overnight. Try it and see what happens one night. Make sure to let us know what you find out!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    No.
    I heated my pool up in case anyone wanted to swim at the big housewarming party after we moved in. A hundred dollars later, it was warm. Three days later, you'd never know I wasted a hundred bucks on natural gas.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You are in the perfect area for solar. I have used solar during this time period before and have gotten my water temps into the mid 80s but it does take a couple of days of warm weather.
    Mark
    38,290
    I turned my solar on a week ago and the kids were swimming yesterday. Water was over 80. Weather has been a bit warmer here though.
    Solar plus a cover will heat your pool right up.
