Results 1 to 9 of 9
Thread: Cya gone to 0
    Nov 2015
    Natchitoches, LA
    28
    Cya gone to 0
    I live in Louisiana and we have had serious flooding. Lots of leaves, limbs and other debris went into the pool and I was not able to work on it for days. It took on lots of rain water to the tip top and overflowing.. It also began to turn green and black. Today is the first day I've been able to get to work on it. Intended to begin Slam today but appear to have no CYA. I tested earlier today straight out of pool and the water showed no CYA. I read on another post that temp can affect the results so took another sample into house and let come to room temp.. Still 0. Or at least less than will register on the TF100 tube.
    I got all debris out of pool. What do I do now? Pour in bleach or address CYA first? I have 0 FC so definitely need to get that up but I don't know if I need to address CYA first.
    The pool looks exactly how it did when I first found all you great people. Looking forward to your advice!
    16 x 32 inground 23000-gallon, 4 ft shallow going to 8 ft deep, concrete surround, Hayward Pro Series High Rate Sand Filter (Side Valve) with new valve and sand, New Hayward Super Pump, Inline chlorine tab feeder (not using) TF-100xl test kit
    Jun 2014
    15,298
    Re: Cya gone to 0
    As a test, add some bleach first. Enough to get to about 4 FC. See how it reacts. If the FC holds fairly well (an hour or so), even with no CYA and direct sunlight, then add stabilizer for a CYA target of 30. Check/adjust pH to 7.2-7.5 first, then begin your SLAM with an FC of 12. If you find the FC getting eliminated almost immediately after adding bleach, let us know.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Cya gone to 0
    Just be aware that the CYA you add to take it to a level of 30 may not show up on your test for a few days. Just slam at the level of 30 you add.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Cya gone to 0
    Hey guys! I remember you!
    Those storms have been unreal! At least you know the basic of what to do this time!
    Do the FC test like said above as soon as you can and let us know what you find. Once we get those results we can tell you want to do next.
    Kim
    Nov 2015
    Natchitoches, LA
    28
    Re: Cya gone to 0
    Okay I added bleach according to pool math to bring FC up to 4 but just tested and it's at 3.5.
    Also, there isn't anywhere close to get stabilizer until Monday. Should I go ahead and raise to slam level now or is there another concern?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Cya gone to 0
    Quote Originally Posted by Brianandmarti View Post
    Sent from my SM-G920V using Tapatalk
    With no CYA, any bleach you add will be stolen by the sun within an hour or so. But I understand not wanting to lose any ground by waiting. SLAM it after the Sun no longer hits it, and it won't matter that you have no CYA. And remember, with no CYA, shock level is only 10 FC.
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Cya gone to 0
    How long after you added the FC did you test to get the 3.5?
    Kim
    Nov 2015
    Natchitoches, LA
    28
    Re: Cya gone to 0
    It was maybe an hour.
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Cya gone to 0
    You are good then! We can move ahead with the other stuff.
    Get and add CYA to protect the FC from the sun. Bring everything inline (PH 7.2) for a SLAM and get started on clearing up the pretty pool!
    Kim
