Results 1 to 9 of 9
Thread: Millon Dollar Idea......?
    Oct 2015
    San Diego, Ca.
    648
    Why don't SWG manufactures (Pentair/Hayward) automate their SWG's to the point where a sensor reads the FC level and adjusts the output based on that reading and a preselected FC level?
    The Pool Owner wouldn't have to manually adjust it as the climate changes.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Millon Dollar Idea......?
    Sounds good but I wonder if the calibration needs would be a PITA?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Cause we probably wouldn't want to have to pay for it!
    mas985's Avatar
    Pleasanton, CA
    11,741
    Do you mean instead of measuring ORP? Because there are SWGs that use ORP.
    Mark
    38,354
    Like Mark said, some try to so this with ORP sensors, but they are not reliable, especially in outdoor pools with the CYA levels we recommend.
    No one has come up with a way to read the FC directly.
    Support the site
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Just seeing the prices on the electrolyte and membranes that it uses gives me a hint as to the price of the sensor.
    chiefwej
    Probably not a viable solution for residential pools. There are several manufacturers of free chlorine sensors. I don't think that they would be affordable for at least several years as the sensor technology decreases in cost. It would he nice to have.
    Beyond the initial cost is ongoing maintenance which would cost quite a bit of time and money. For now, FASDPD is the best method.
    Support the site
    Apr 2013
    Sacramento, CA
    2,769
    The problem with all the auto sensors is they require regular calibration. In addition the Hatch sensor, which basically uses the differences in conductivity of the water to derive a chlorine concentration, is sensitive to changes in ph and temperature. In short its readings can vary depending on the ph or temperature of the water. If you have a situation with constant temperature and ph then you can rely on the result, if you don't have that situation then its more problematic.
