Thread: Check valve choice?
    Apr 2015
    Central New York
    6
    Check valve choice?
    I will be reinstalling my pump and heater soon. This year I would like to put a check valve at the heater to prevent high chloride water from back washing into the heater when the pump goes off. I am using an offline Hayward chlorinater which injects after the heater.
    What is the recommended style of check valve? Flap or spring? Or am I just over killing my thought and the valve is not necessary? Thanks.
    In-Ground,14000 gallon, 15x33 fiberglass pool, starclear plus 1200 cartridge filter, tablet chlorine feeder, Hayward 1.5 hp pump, unheated
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Check valve choice?
    I'm not sure I understand your question. Are you talking about keeping water from an in line Chlorinator backing into the heater? In whatever case, I'd think a standard spring flap type would work. That's what mine is. If you really wanted to fancy it up, you could add a FloVis that would give you flow indication, and the same thing all at once.
    Essential Links:
    Apr 2015
    tucson, arizona
    1,121
    Should always use a corrosion resistant one. There are several available. One of the best is made by Magic Plastics
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    If you are going to install a check valve then one of these Jandy styles is the best because it can be easily service down the road.
    Pool Check Valves. Swimming Pool Check Valves.
    I don't think it is really necessary. The real question is are you really sure about using that trichlor puck chlorinator? Each puck adds a lot of CYA and it won't take long before there is too much CYA in your pool. More here, Pool School - How to Chlorinate Your Pool
