Results 1 to 9 of 9
Thread: Opinion on Timers with Pump & SWG
    Jan 2010
    Randleman,NC
    620
    OK,been running pump timer on SWG timer.Who runs this way.Concerned because SWG stays on all the time.Will this mess the System up like this?Is system still working while there is no water flow?
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    38,547
    Re: Opinion on Timers with Pump & SWG
    I am not sure what "running pump timer on SWG timer" means.
    Doesn't the AquaTrol have a built in timer that is designed to turn the pump on and off? I would think that the SWG was designed to not operate when the SWG timer is not on. There may also be a flow switch that is a backup to prevent the SWG from generating when there is no flow.
    Jan 2010
    Randleman,NC
    620
    That's what I was wondering.Is the SWG still working with pump off.I would not think so because of no flow thru the cell.New for me this year.
    38,547
    The lack of flow through the flow switch should certainly shut down production. But that is generally supposed to be a backup to the power being cut. I guess I am not sure if there is an internal tie between the built-in SWG timer and the SWG production ... I would assume there is as that would make sense, but I am not certain.
    Sounds like you are using it per its design, so should be fine.
    Jan 2010
    Randleman,NC
    620
    What I have read the timer just controls the pump.Has nothing to do with the SWG itself. Power to the generator shows on when pump is off
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    According to the manual, here, https://www.google.com/url?sa=t&sour...EJRyM9YXPpA9Fw, there is a POWER LED and a GENERATING LED
    From the manual,
    Indicator LED's
    POWER When illuminated, the Aqua Trol has input power.
    GENERATING This LED is on steady during normal operation. When flashing, the pool water is too hot or cold to operate.
    The main switch should be left in the AUTO position, is that where yours is set?
    From the manual,
    Main Switch
    AUTO: For normal operation, the Main Switch should be left in the AUTO position. In this position the Aqua TrolŪ will produce chlorine according to the "Desired Level %" adjustment setting for the entire filtering/pumping cycle.
    Jan 2010
    Randleman,NC
    620
    Yes,it's in auto.My ? Is when pump is off is the SWG working .Shows power.I have it set s 30% now.I haven't seen the generating light come on with pump off.I figure the no flow of water will sense not to produce chlorine
    DFW, TX
    24,517
    If the generating light is not on then cell is not on.
    Jan 2010
    Randleman,NC
    620
    Thank You
