Results 1 to 9 of 9
Thread: White crystals formation
    Feb 2016
    Plano
    20
    Hi all,
    I am noticing white crystal like stuff popping up in the pool. They are very hard and hard to remove with hands. Does anyone know what this might be and how to remove them?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: White crystals formation
    It looks like efflorescence. There are probably hairline cracks in your plaster right where those crystals are, and the water gets behind it and starts reacting with the shell material.
    Feb 2016
    Plano
    20
    They are actually everywhere. More than i could count. Even on the floor of the pool.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    What's your calcium test reading?
    Dolphin E10 Cleaning Robot.
    Feb 2016
    Plano
    20
    I just took the readings.
    Fc 5.58
    Ph 7.6
    Ch 208
    Cya 50
    15000 gallon with spa, plaster, hayward ctg filter, advantageman 2hp motor, bleach, poolvac XL
    Feb 2016
    Plano
    20
    Can someone please suggest? It is increasing and are even seen on more spots. I went to Leslie's pool and they think it is calcium deposits.
    I also tried to reduce PH with acid but have not been successful. Here are the latest readings.
    Fc 4.37
    Ph 7.8
    Alk 111
    Ch 252
    Cya 48
    Here is the pic.
    Jun 2014
    15,298
    A couple questions to help us reply to your last couple test results:
    - What test kit was used to get those results?
    - Do you have a SWG (salt water generator)?
    It would also be helpful if you listed all of your pool details into your signature. You can do this by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later. This link may also help you: Pool School - Read This BEFORE You Post.
    Feb 2016
    Plano
    20
    Quote Originally Posted by Texas Splash View Post
    Thanks, Just updated my signature.
    I use ColorQ digital.
    I do have SWG system but Cell is not working. I use bleach for chlorine.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Are you in Plano, TX? Please add your state to your location in your profile so that it shows up over there <-------
