Thread: Light Conversion Fiber Optic to LED
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Have an old non-functional fiber optic system currently. 2-3 (no I can't remember) in-pool lights with a fiber rim-light (which is definitely not being replaced). Anything special about a conversion to LED? I assume I can run the LED power to and from the lights through the same conduit the fiber came through, yes/no? My thought is to use the old fiber optic tower as a bit of a wiring box for the LED as the 120v from the house is located there.
    Any recommendations?
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Apr 2013
    Sacramento, CA
    2,769
    Re: Light Conversion Fiber Optic to LED
    We are not at your pool so we can't tell you for sure if what I describe bellow will work but it has worked for others.
    Replace the Fiber Optics with Nicheless lights. Pentair GloGrights are an example. There are others.
    Your replacement has to comply with the National Electrical Code (NEC). In general the NEC requires that the light cord terminates in a "listed junction box" that meets certain specifications. So you can't use the fiber optic tower. Pool supply stores carry listed junction boxes.
    Before doing the work read this: http://www.mikeholt.com/download.php...as_2014NEC.pdf
    The section you are interested in, 680.23, starts on page 13.
    If you understand what he is talking about and feel you could do the work described then go for it. Otherwise hire a professional.
    Jan 2012
    340
    Be careful what nicheless lights you purchase for a retrofit. Globrite, for example, are not used for conversion. They require a Globrite specific niche. I see most people using the Zodiac Savi lights, Zodiac watecolors, or SR Smith Pal Treo lights. These are all made to fit in a 1.5" SP1022 fitting, which is what fiber optic lights are typically fitted into. You have to consider the amount of straight 1.5" pipe behind that fitting, as well. Many of the smallest lights require at least 4" and others require more. The Savi Buddy light is one of the shallowest and works well in most fiber optic conversion applications.
    Ditto on the installation advice above.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Thanks for the replies! Didn't mean to suggest I would use the old light tower as the actual wiring box for the 120V just a hub of sorts for everything going on. Should I hold off on purchasing lights until I see how much straight pipe I have to work with? Do I need to measure the actual run of conduit (from "niche" to the light tower) either?
    Jan 2012
    340
    Yes and yes.
    Pull the lenses and see what is behind them before you spend money on lights.
    Most lights are sold in different cord lengths. Less copper = less $$. Get what you need unless you find a good deal or you want to make an extension cord with your leftovers.
    Most LED lights are 12V, so you'll probably be putting a transformer where your old light source is.
    Apr 2013
    Sacramento, CA
    2,769
    You need a pool rated transformer
