Results 1 to 8 of 8
Thread: Aeration Question
    May 2014
    Las Vegas NV
    45
    Aeration Question
    How long after adding muriatic acid to lower ph to 7.0-7.2 do you have to wait before starting to aerate?
    Thanks in advance!
    Any help appreciated
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Re: Aeration Question
    I also want to know, so bumping it up to top.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jun 2014
    15,153
    If the purpose of lowering the pH was originally intended to low TA, you can aerate right away. That way the TA stays lower and you get the pH back to the recommended level before doing it all over again.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Immediately. I add acid with the pump on... which means there's already water coming over the spa spillway, so I'm actually aerating the water before I can get the cap off the jug!
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Am I correct thinking it is better to leave the solar blanket off while aerate? don't mean to hijack post, but is related.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Aeration is increasing the air/water interface area. Having a solar blanket on the pool does the exact opposite.
    chiefwej
    May 2014
    Las Vegas NV
    45
    Is it ok to use a solar blanket when not aerating?
    Richard320's Avatar
    Jan 2010
    19,009
    Quote Originally Posted by badgerwooz View Post
    Sure. Besides warming the water, it lessens evaporation, which means you need to add less refill water, which means less Calcium buildup.
