Thread: What are "heat sinks"? Why are they so expensive?
    Jun 2008
    western Wisconsin
    250
    Last year, we sprung a big leak in the pipes between the pump and heater, and opted to bypass the heater. (It was around 90 every day.) The PB did the bypass, said we needed two new heat sinks at $95/each, recommended that we get a new heater instead of fixing the old one, and took all the connecting pipe. Honestly, I'm not sure what heat sinks are, but I know we can't afford a new heater. Since we opened early this year, I'd like to get the old heater fixed, but I'm reluctant to spend the money on it when I don't really understand it what's wrong. Can anyone educate me about heat sinks, old natural gas heaters, etc.? The heater is a Teledyne Laars XE, and we think it was original equipment -- maybe 10-15 years old. (We bought the house last year.)
    26000 gal, in-ground, vinyl pool
    Hayward S200 sand filter, 1 skimmer, 2 returns
    BBB since the first month! :-)
    Mar 2008
    Los Angeles, Ca
    222
    Re: What are "heat sinks"? Why are they so expensive?
    Here is a diagram of your heater
    http://www.mypool.com/Help_files/Parts_ ... dyeXE2.htm
    I did not see heatsink anywhere, not sure that it is in a pool heater.
    I would ask the guy to point out what is bad.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Jun 2008
    western Wisconsin
    250
    I called a few places ... it looks like they are the stainless or copper pipes that connect the heater to the PVC. I think they are called "heat sinks" because they absorb the heat so the PVC doesn't melt. Can anyone confirm that?
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    You are correct, and using heat sinks is pretty much "old school". Since most new heaters have capron headers, or recommend CPVC close to the heater, they are no longer used.
    Finding a set of heat sinks is not that easy anymore! They are, indeed, copper or SS. A new heater will not require them.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
