Thread: Spa (minral frog capsule)
    Aug 2015
    Arnhem/Netherlands
    109
    I read now after 12 months it is better not to use the frog mineral casule.
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    Donldson's Avatar
    NW Ohio
    2,896
    Re: Spa (minral frog capsule)
    Silver ions are useful in a hot tub to prevent algae and provide a secondary source of sanitation. If you are maintaining proper chlorine or bromine levels then it won't provide much help (chlorine and bromine kill times are much faster than silver) and excess silver can potentially cause staining.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2015
    Moncks Corner
    18
    Good to know - I always wondered how necessary it was. I'm also starting question the necessity of the bromine cartridge as well (other than if gone on vacation for a week). We use the tub daily or every other day typically and hit it with MPS after every use. Br levels don't seem to drop any different with the frog in or out.....
    edit - well, I just saw the other thread on the frog - I believe I'm done with it. - Thanks TFP!
    Jacuzzi J-325 with ClearRay, outdoors, Bromine
    Donldson's Avatar
    NW Ohio
    2,896
    Since you use the tub regularly there really isn't much need for bromine tabs unless you will be away for a few days. Just using MPS or bleach after you soak will keep your bromine levels high enough for daily or every other day use.
