Thread: Some residu on the shell (see the test results of the water)
    Aug 2015
    Arnhem/Netherlands
    109
    I have some greasy residu on the sell my nr,s are.
    Ph 8
    TA 94
    CYA 24
    CH 1.3
    I have ad Boratic 1,5 month ago.
    What to do first now
    My spa is 225 gallon (ca 900 ltr)
    Factory is Caldera
    Above ground
    6 months old now.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Some residu on the shell (see the test results of the water)
    Edwin, it looks like your PH is high, should be around 7.2/7.4 Also, you do not show your free chlorine level or are you using bromine? Also, if you bring your TA down between 40 to 60 your PH will not rise as fast.
    Can you get Ahh some, it is worth every penny and works great... you would follow the instructions and clean you spa, empty the water and refill and balance then enjoy your spa again..
    HOME
    Ahh-Some for Jetted Baths, Hot Tubs Swim Spas - Ahh-Some Water Cleanser for Your Pool, Hut Tub, Jet Bath, Swim Spa and Washing Machine
    Aug 2015
    Arnhem/Netherlands
    109
    Yes indeed PH is to high i have put in PH minus till TA is down to 50.
    and The PH till 7.4.
    Free chloor is 1.3 sorry and i,m using bleach
    Thanks.
    Factory is Caldera
    Above ground
    6 months old now.
    Jul 2013
    Fletcher, OK
    3,353
    no problem, you could try to SLAM your spa, it is exactly like a pool just smaller I do a SLAM about every 3 months just to rid the combined chlorine that rise cause I have the lid on all the time. this would be the next best thing if you can not get the ahhsome..
    Also, with a 225 gallon spa you may need to replace the water about every 4 months depending on how much you use it... I tend to replace mine at 6 months but I have close to 700 gallons. If you do replace the water, do a SLAM before you empty to clean all the gunk out of the pipes and them empty it.
