Thread: Brown stains and dry acid
    Feb 2016
    Brisbane, Australia
    11
    I've noticed brown stains in the pool recently. I found this post (Brown stains not from iron) which recommends vitamin C tabs as one of the tests.
    I assumed I need something acidic, so I use dry acid (the stuff I use to lower pH levels). Placed a bit in a sock and "painted" the pool wall, and the brown came off quite easily (only a tiny bit of pressure required)
    Was it ok to use dry acid as a substitute for vitamin C tabs?
    Could this be an iron stain? (they are all over the pool, bar a couple of spots).
    Pool size: ~50,000L vinyl, Pump: ???, SWG: AutoChlor RP25T
    Filter: Sand, Test kit: Taylor K-2006 (FAS-DPD)
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Brown stains and dry acid
    Dry acid is mostly sodium bisulfate which can form very strongly acidic solutions. It will definitely remove metal stains but it can also be quite corrosive to plaster. Ascorbic acid, on the hand, is less acidic but very good at removing iron stains because it is also a chelating agent. AA is the preferred way to perform the test for metal stains as it is non-destructive to plaster.
    That said, it sounds like you have metal stains and that an AA treatment will help.
    Matt
    Feb 2016
    Brisbane, Australia
    11
    Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
    Thanks Joyful.
    Note to self: don't use dry acid for testing like that again My pool in vinyl so I hope i'm ok! (only a small area tested anyway)
