Results 1 to 14 of 14
Thread: Help identify equipment
    Mar 2013
    Houston, TX
    21
    We are having some work done to replace some of the pool deck - and in doing so some of the plumbing got damaged. In cutting out some of the pipes I found this on the main drain pipe (along with some very convoluted joints). It was buried about 2ft below ground.
    Can anyone help me identify what it is - and whether I should replace it?
    Thanks in advance!
    25k IG plaster. Jandy everything: cartridge filter, 2sp pump, SWG, Aqualink PDA-PS6, Heat pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Help identify equipment
    It looks like a check valve.
    Mar 2013
    Houston, TX
    21
    Interesting - makes sense as the equipment is a few feet above the pool. Never seen one like that - but the pool is pretty old.
    I should probably put a new one in then?!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Yes, I would put it at the pad so it is more easily serviced.
    Mar 2013
    Houston, TX
    21
    I think they need a decent column of water to keep the seal...so the pad might not work. Maybe put it in an irrigation box?
    DFW, TX
    24,514
    One of these on the equipment pad will work great and can be easily serviced when the time comes.
    Jandy Spring Check Valve 7305. Jandy 7305. Zodiac 7305.
    Mar 2013
    Houston, TX
    21
    Ok - spring loaded so it doesn't require the water pressure? Thanks!
    Apr 2013
    Sacramento, CA
    2,769
    Looks more like a sewer clean out to me. I don't think its a check valve. Which makes no sense but then burying that whatever as part of pool plumbing makes no sense to me either.
    Can we get a picture of the equipment pad and the pool?
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    I vote for sewer clean out also.
    I have clean out like that under my Trex deck (a lift off panel) that opens easily and I can drop my hot tub's sump hose into when draining. It goes across my yard and under some pool deck cement to the large county sewer pipes down hill.
    Mar 2013
    Houston, TX
    21
    It does look a bit like a clean out trap - but it's definitely on the main drain suction line. I'm going to clean it off today and see what's what....
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Gentlemen, that is not a sewer clean out. That is a check valve...
    Factory Warranty Station for:
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by Noelep View Post
    The spring helps keep the valve closed, not open. It adds head loss but is necessary under certain conditions.
    Mark
    Mar 2013
    Houston, TX
    21
    Update: Yes it's a check valve. And I was wrong about it being the main drain suction line - it is actually the spa return. (Both 1.5").
    Glad I noticed or I would have the new valve in the wrong way!
    That aside - the spa return actually has a check valve type nozzle on the jet. Wondering if that means I can do away with one on the line.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Keep/install a check valve on the spa return side. Jandy and Pentair both make good ones that you can replace the "insides" when, in time, will fail, without having to cut out the old housing and plumb in a new one. Just don't bury the check valve it you want to be able to service (you will want to).
    Very slick IMO.
    BTW, the check valve in that picture does not have a spring in it. the flapper is brass and seals nicely closing under its own weight. Drawback is that it can only be mounted in one of two ways to make that happen. Laterally, only with the plug facing up, and vertically with flow only upwards.
