Thread: Help
    Mar 2016
    henderson, nevada
    1
    Help
    My power went out th other night and the next day my pool didn't go on. I don't know how to reset my timer
    Jun 2014
    15,292
    Re: Help
    Hopefully it's something as simple as resetting a breaker or two that supply power to your pump and/or system. Have you checked your breaker panel? If that's not helping, can you give us a better idea of what kind of equipment you have? Is it an automated-type system?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Help
    If you have an Intermatic, it's easy. Just grab the yellow dial and pull out and turn it to the right time and let it go back in.
