Results 1 to 12 of 12
Thread: TF-100 options
    Mar 2016
    New Albany, Mississippi
    176
    TF-100 options
    How can I know what options to the TF-100 test kit I should get for the type of pool I am building?
    I am ordering the TF-100, plus the speed stir and the Taylor Salt test kit since I will have a SWG.
    I am building an approximately 30K gal., vinyl liner pool with a SWG. Do these seem like the best option or are there any other additions, I should be considering?
    -Mickey
    30,431
    Re: TF-100 options
    Mickey,
    I think you have it about right. The speedstir is a terrific addition.....everyone loves it.
    Many folks get the XL option to double up some of the reagents but it is more pointed towards someone with a green pool.
    For your new pool, I think I would get just what you are already considering.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,584
    Re: TF-100 options
    I would get an extra magnet of two for sure in case you lose one.
    Kim
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: TF-100 options
    I'll second the idea of back up magnetic beans. I will admit to the stupidity of having tossed a few away by accident when hurling the test tube contents into the grass. Ugh! You'd *think* they would be easy to find in the grass...but not so much in the juniper, monkey grass, mondo, yada yada yada. Get an extra bean.
    I now keep one for each test tube also, so that I can move right along with my testing without having to stop and clean up one tube to get that bean out. I do all my tube cleaning out at the end.
    Jun 2014
    15,212
    Re: TF-100 options
    It sounds like some of us need to get a metal detector as well.
    Jan 2012
    7,367
    Re: TF-100 options
    Isn't that what Skippy's lawn mower is for??
    30,431
    Re: TF-100 options
    Mar 2016
    176
    Re: TF-100 options
    My test kit arrived today. What tests should I do on my water before my pool is built, or should I?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: TF-100 options
    You can practice on your fill water if you like. FC, TA, CH especially.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: TF-100 options
    Quote Originally Posted by wmmallette View Post
    You can test the fill water for practice. Check chlorine, pH, TA, CH. You won't have any CYA, so save the reagents.
    That'll tell you if you're likely to need to have acid or borax or baking soda standing by. A lot of us never ever have to add anything to raise TA or pH, so if you're one of us, there's no point in having a supply onhand. With a vinyl liner, you'll never need to buy Calcium Increaser, but you should know the CH number so you can be aware of the potential for scaling.
    Mar 2016
    176
    Re: TF-100 options
    I'm not on a well, but I am on a rural water association and have had some instances of brown water in out house. I thought it might be helpful to see about metals.
    Richard320's Avatar
    Jan 2010
    19,050
    Re: TF-100 options
    The Tf100 doesn;t have a metals test. But you'll know quick enough when you start filling. You may see rust sediment or the water may look yellow or green, or it may look fine but turn green as soon as you add bleach. Worry about that if it happens. It can be dealt with.
