Spa tiles loose
boston62
489
Fort Myers, Florida
any ides on how to replace these tiles that we're loose, I took them off. I didn't see any water behind the tiles.
Sent from my SM-G900P using Tapatalk
Yeah to make them stand out as in "I meant to do this and it is so pretty and different". More of an accent than a fix kind of thing. Of course I am not the one that has to cut the tiles to make them fit so.........
Kim
after replacing my tiles, I had a lot of old tile set fall into the pool, I did remove the big pieces , but my pool is cloudy with the light on at night, I am hoping this is from the old tile set. I shouldn't be using chlorine, or would it affect the chemistry? Thanks
What are you latest test results? Best to check those first....
If the numbers are fine I wonder if it is "dust" or such from the tile fixing. I would put a skimmer sock on to help you filter the finer stuff out of the pool. I am hopeful that over time your sock and filter will get them out.
Kim
