Thread: Pool Deck Hole adapter (for B-ball goal)
    Sep 2015
    Bloomington IN
    27
    My concrete pool deck has two 1.9 diameter holes for volleyball, bball, etc.
    http://www.aqua-games.com/products.htm
    The only b-ball goals I can find that slide into this are over $400!! Does anyone know of a sleeve that I can fit in these holes that will change the size to a larger opening? That would then give me some more options.
    Bill
    14000 Gal, Vinyl Lined Pool, No salt
    JoshU's Avatar
    New Orleans, LA
    543
    Re: Pool Deck Hole adapter (for B-ball goal)
    Dunnrite Products makes products in this area as well. I am not aware of any premade adapters. The 1.9" size is pretty much industry standard for sleeves.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Sep 2015
    Bloomington IN
    27
    Looks like 1.9" is the OD of a 1.5" PVC pipe. I'm thinking I could figure something out with PVC fittings.
    Bill
