Results 1 to 15 of 15
Thread: Why our heads are about to explode....
    Aug 2014
    Shallotte, NC
    693
    My wife and I are walking around with pounding headaches.... and I just got graphic evidence as to why......
    This morning, I looked into the skimmer and there didn't appear to be any water moving. I had the immediate "Oh, no, the pump", thought, then noticed the skimmer sock had turned an off-yellow color. I had to turn the pump off to remove the basket and found a 1/32-1/16 layer of pollen that had built up over a period of 24 hours. There was clearly a thick yellow "oil slick" on the pool yesterday, but I had no idea.... even though we have been vacuuming pollen sediment for a week or more.
    I think this is the worst pollen season, ever....
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Why our heads are about to explode....
    Here in OK it is the worst I have ever seen, Just had to get a Z pack for the first time ever because I could hardly breath... Its so bad my allergy medicine won't even work, I am having to take the old standby Benadryl... Just crazy this early in the season...
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    I walked out and just THOUGHT I had a red car...............it is YELLOW! So thick I had to spray the windshield to help clear it!
    Kim
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    I have a yellow cat for sale. Washed----she's normally jet black!
    Dec 2015
    arlington, tx
    100
    as billy crystal would say, "i hate it when this happens!"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    What a misleading title. I just assumed the neighbors were playing their Slim Whitman album too loud.
    Jun 2015
    Ottawa/Ontario
    336
    Climate change?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    What's the TFP party-line on this.....do we blame all the extra pollen on global warming? Is this a sign of the apacolypse? Or is it all Obama's fault?
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Blaming Obama sounds good but I think it's from a mild winter. Water temp still 58 ish so I'm debating weather to suffer the pollen and take the cover off.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2014
    Shallotte, NC
    693
    Jul 2014
    Hope Mills, NC
    567
    Its Bush's fault.
    Actually, I though last year was worse.
    Strange winter here in NC for sure.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2014
    Shallotte, NC
    693
    Quote Originally Posted by smforte View Post
    I'm going with global warming. We had nearly no winter..... some plants actually bloomed all winter; I've never seen that before. Virtually everything was budding out at the end of January. We've had one day below freezing since December 1 and I was never really able to close the pool, since the water temperature has only been below 60 degrees 17 days in the same period. In past years, frosts and snow wouldn't have been unusual, through the first week, or so, in April.
    High today of 78 and pool temp is 74-75 degrees.
    Yellow haze back on surface of pool.... I'm dumping the skimmer sock twice today....
    Apr 2013
    Sacramento, CA
    2,769
    Ok Ok Richard I'll turn down the Slim Whitman but my daughters into Pentatonx so I have no control over that.
    Jul 2012
    Cary, NC (Raleigh)
    69
    I do enjoy the nice winter we've had here in NC.
    While I usually wait for the yellow snow season to end before opening up our pool; this year I"ll be doing it early probably next week, fire up the heat-pump, and let my allergies suffer through it for a bit.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
    Lou.'s Avatar
    Oct 2015
    Rowlett TX
    63
    We just a yellow ring on pool tiles. I had to hand scrub it off. My fam n neighbors are breathing n sneezing n coughing for the first time from allergies. I blame GMOS.
