Thread: Polaris PB4-60 Booster Pump Wiring Help
    Where do my red and black wires get hooked up to? Tried #1 and #2 terminals. Sparks flew. Where am I going wrong? Posted the diagram at the link below. Please help, need my booster back!
    http://www.4shared.com/dir/14952755/f52 ... aring.html
    Evan
    Pool size = 13,000 gallons. Sand filter. In Ground. PebbleTec.
    37,887
    Re: Polaris PB4-60 Booster Pump Wiring Help
    Welcome to TFP!
    That motor is configurable for either 110 volts or 220 volts, which it calls Lo and Hi. You need to figure out what voltage your supply is and adjust the white and brown wires to the corresponding positions.
    Apr 2009
    Sarasota Florida
    143
    Power in goes to 1 and 2 where it says line. Then move white and brown to their proper position depending on your incoming voltage. Make sure power is off. It is possible if you put 220 and it was wired for 110 that you may have damaged the motor.
    If you are unsure of you incoming voltage you can either disconnect them from the motor and use a voltage meter, or possibly look at your breaker panel and see how breakers are for the pump. 220 will usually have 2 breakers while 110 will have 1.
    Mike
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    Yeah forgot to mention I need to wire for high voltage, which comes prewired from the factory. I'm thinking my connections might not have been tight which might have led to the sparks. Does this seem possible? Thanks for the replies!
    37,887
    Lose connections could easily spark. It is also possible that you had exposed wire too close to one of the other terminals and it was sparking across to there.
