Thread: "chalky" residue on shell
    Nov 2015
    VT
    84
    I use softened water at fill up.
    I use bromide+bromine tabs and bleach per the sticky here.
    I use a Taylor test kit and maintain the water perfectly.
    I just did a drain/refill and noticed that, below the water line, the tub looks "chalky".
    What is it from and what's the best way to remove it? (it didn't come off with a sponge+Ahh-Some)
    The tub shell is a textured plastic, not a high-gloss acrylic.
    Hot Springs Sovereign (1999?)
    Jun 2014
    14,987
    Re: "chalky" residue on shell
    Brian, can you post a full set of test results please? That will be very helpful as we try to evaluate your situation. Thanks.
    FC
    CC
    CYA
    pH
    TA
    CH
    Nov 2015
    VT
    84
    I don't have the exact #s handy but they are always kept at recommended levels.
    Jun 2014
    14,987
    Typically when we hear of a chalky residue situation, we think of a potential calcium issue. But it's not always as easy as just getting a CH reading or assuming right away it's scale. Not that we don't trust your capabilities, but seeing all the results would be of great value. Just whenever you get a chance, try to post those for us so we can put everything into the poolmath calculator ourselves and compare.
