Results 1 to 7 of 7
Thread: Brand New Pool (6 days old) - Junk in my Water?
    Jan 2015
    Phoenix, AZ
    27
    Hi All,
    I just filled my brand new pool. I posted my #s in another thread (CYA looked kind of low, TA was high, the rest was OK), but this question isn't really related. When I look down at my water during the day, it's crystal clear. However, if I look down at it at night with the light on, I see lots of stuff floating around (or maybe little bubbles?). I tried to capture it in a pic, but it's hard to capture correctly. Is this normal?
    Note that this was taken after sweeping. I swept with the filter and cleaner running, then let everything settle for ~5-10min before snapping the pic.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: Brand New Pool (6 days old) - Junk in my Water?
    It is VERY normal. There is NO filter out there that will get ALL of the partials out of the water. What you are seeing is a very tiny amount compared to some other pictures others have shared. Stuff is being added to the pool every day from the wind and people in the water.
    Now go jump in your pool and enjoy it!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Floaters are normal.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    You have a cartridge filter and the are very good at filtering but DE filters capture the most... What you are seeing in the light is below about 5 microns, so really small
    Jun 2013
    South Florida
    118
    What you may be seeing is microscopic bubbles from the SWG. As the cell is working, it produces microscopic gas bubbles. If I watch my return jets at night with the pool light on, I can see the bubbles coming out. Then you can see it throughout the pool water.
    Turn your SWG off completely and run the pool pump for a few hours. See if it becomes clear. Your observation is the same as mine, it can only be noticed at night with the pool light on.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
    Jan 2015
    Phoenix, AZ
    27
    Thanks for the responses, everyone!
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    I recall when our pool was new reading here that the very best time to vacuum a pool is at night with the lights on. EVERYTHING shows up almost magnified! LOL.
    Nothing wrong with your pool water, you're just seeing it more at night.
