Results 1 to 7 of 7
Thread: Can someone educate me on zinc?
    Nov 2015
    Boston, MA
    120
    New pool and will be putting in the salt chlorinator come spring. Can someone educate me on zinc anodes? I saw that they have some that just go in your skimmer basket. How do these work or should I get an inline? How do I hook it up?
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: Can someone educate me on zinc?
    Noooooooooooooooooooooooooo to zinc in the skimmer!!!! It is absolutely the wrong thing to do.
    Zinc is used as a sacrificial anode when it is electrical connected to a dissimilar metal. It is designed to corrode instead of the metal you connect it to. Not only is salt water a lousy way to connect dissimilar metals but it will not protect anything in the water. All you will do is load your water up with zinc cations (zinc has a solubility limit of ~1ppm at pool pH) and the rest of the corroded zinc oxide will just land in your filter.
    It's just fundamentally a bad idea based on a total misunderstanding of electrochemistry.
    Matt
    Nov 2015
    Boston, MA
    120
    So no the oNE I read about hooking up to bond and burying?
    May 2015
    13,201
    Quote Originally Posted by moreira85 View Post
    You can hook up a zinc sac-anode to the bonding wire and that will do an ok job. Just don't put any zinc in your water.
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Agreed, it can't do anything but add Zinc to your pool in the configuration you mentioned first.
    Essential Links:
    Nov 2015
    Boston, MA
    120
    Got a link for a recommendation 4 a product?
    May 2015
    13,201
    If you look up "zinc sacrificial anode" on Amazon you'll find a lot of products for the boat market. You might find something there that works for you. You could also call around to plumbing supply shops and see if anything is sold there. Unfortunately there's no product specifically designed for the DIY Pool market.
    Matt
