Thread: ? concerning in-floor cleaning systems
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    When operating the in-floor cleaning system, is it better to pull water in from the floor drain or from the skimmer?
    I would think it would be more efficient to pull water from the main drain as the larger particles don't always stay in suspension long enough to get to the skimmer. Let's hear your thoughts.
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: ? concerning in-floor cleaning systems
    Does it have to be either/or? The best answer is to use both.
    An in floor cleaning system blows debris towards the main drain, so you normally want the main drain on at least somewhat when using an in floor system. The skimmer is designed to deal with floating debris, so you want that one most of the time as well.
    I guess this is a bit of an old thread, but I'll respond anyway. I adjust mine depending on what's going on. If a storm drops a lot of floating leaves in it, the I'll open the skimmer valves wide open and close up the main drain. If I have a lot of gunk in the bottom, I do the opposite (I have a tree over the pool that drops floating stuff sometimes and sinking stuff at others). Most of the time, I have one skimmer off, the other skimmer about 1/3 open and the main train a little over half open. If I get a lot of sticks in the pool, I'll close off the main drain and clean manually, because it has a tendency to get clogged.
    20,500 gal gunite pool w/ PebbleTec and infloor cleaning system.
    Sta-Rite System 3 cartridge filter.
    Houston, TX
