Results 1 to 7 of 7
Thread: MisplaceTexan, Possible New Pool Owner
    Feb 2016
    Baytown, Texas
    40
    I currently am shopping around for a pool builder in the Houston Texas area. I live east of Houston. Would just like some recommendation for the equipment that was recommended by my 1st pool builder.
    Pool Size: 16 x 34 ft
    Pool Depth: up to 67 ft (??? - will be contacting pool builder to find out what this means)
    Pool Area: 485 ft²
    Filter: 48 sq ft - Pentair FNS Plus D.E. Filter
    Pump: 1.5 HP - Pentair Whisperflo Pump (99% sure will be requesting VS pump)
    Valves: Never Lube Valve 2"-2.5"
    Skimmers: 2 CMP; 2" Lines Separate Line & Valves. Tann Skimmer Lids to Match Deck
    Main Drains: 2 Main Drains - Separate Lines & Valves
    Pool Light: 1 x Pentair Amerlite White 500W w/ GFCI (will be requesting LED)
    Time Clock: Intermatic Dual Timers
    Cleaner: Polaris 280 with Booster pump
    Sanitizer: Jandy AquaPure Ei Salt System
    Ozone: Ozone Joe Water Purification System (will be requesting this item to be removed off quote)
    Inlets: 5 pool return inlets
    https://youtu.be/vubK7Ui7eaM
    https://flic.kr/s/aHskwkbFKM
    Any help or suggestions are deeply appreciated.
    Xavier in Baytown, Texas
    Pool Built: 06May2016. 16ftx34ft, Area: 485 ft2, Depth: 4ft-6ft, Pentair IntelliFlo Variable Speed Pump, Pentair FNS Plus D.E. Filter 48 sq. ft., Easy Touch 8 with wireless remote, IntelliBrite Pool Color LED, 640 Sq Ft of deck, 3 ton waterfall, Guesstimation: 17,000 gallons, Test Kit: Taylor K-2006C.
    Jun 2014
    15,103
    Re: MisplaceTexan, Possible New Pool Owner
    Welcome to TFP! That looks to be a gorgeous project, and you've done a good job with the initial listing. Some solid products there, and you already CANX'd the ozone. Others will reply I'm sure, but I'm not convinced about the 2-main drain requirement. You should get most of your circulation and surface debris removal from those 2 skimmers and return jets, but that's just one opinion. Maybe look carefully at the positioning of the 5 return jets. Since you have some subtle curves, there is always the potential for "dead spots" in circulation. Perhaps you may need a couple more returns instead? As for the SWG, the web site says up to 35K gallons. I'll let others confirm that selection. Requesting LED lights - nice. You're on the right track. Welcome!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,494
    I'm not a fan of single speed pumps. If me, I would upgrade to a variable speed pump, or at a minimum, a two speed pump. Do it now and you can thank me when your electrical bill arrives.
    In the end, the overall cost to upgrade would be minuscule compared to the overall cost of the pool.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    OH that is pretty! I can't wait to see you over in the "under const." section!
    Kim
    Apr 2016
    Houston, TX
    208
    Welcome, I'm also in process of starting a build thread, your PB will be doing mine aswell, Im like you trying to do as much research as I can in this great website.
    38,281
    Welcome to TFP!!!
    I would also recommend ditching the booster pump and pressure cleaner and getting a robot instead.
    Casey's Avatar
    SW PA
    10,438
    Welcome to TFP! That will be a beautiful pool!
