Results 1 to 15 of 15
Thread: Impeller help needed - please see picture
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I'm trying to run my pump and it seems to start well. However no water is flowing and there's a loud rattle.
    I tool apart the housing and found the following...
    ...what do I need to do? Don't want to go any further without consulting the forum.
    Thank you!
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Impeller help needed - please see picture
    Did you unscrew the impeller or was it loose like that?
    It might be a good idea (whatever you do) to get a seal replacement kit while it's apart.
    What do the other parts look like? (diffuser / other piece you took off)
    Dolphin E10 Cleaning Robot.
    Oct 2015
    Katy/Texas
    411
    We need to know the whole story. Are the impeller passages clean? What does the rest look like?
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Quote Originally Posted by WASP View Post
    All internal cavities of the housing (and impeller) were clean of debris and all water came out before taking anything apart.
    Quote Originally Posted by borjis View Post
    The impeller was already like that.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Another note: I've only had this for a couple of years so if the Shaft Seal can be kept I'd like to as it's not that old yet. Does the picture look like I have to clean broken plastic out of it?
    Oct 2012
    209
    Chip/ cut the rest of the impellor off, replace shaft seal (better to do it now than get it put back together and it leak....they are cheap enough), and replace impellor.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Ya even though your seal may not be that old, they are cheap and you don't know what kind of damage
    it has since the impeller came off...could be little bits of plastic that got in. Any of that would
    shorten the life big time. I've seen leaking pump seals that look like new so a visual inspection
    won't tell you anything.
    You can probably do an amazon search for "pool pump impeller" then add the serial number
    from your impeller to get a new one.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Okay - just ordered replacement parts. Kind of a silver lining as apparently this pump could have one of two impellers (a 3/4hp or a 1hp) and it was built with the weaker of the two. Not sure why they would do that if the motor is 1.5hp but... A good opportunity to increase flow!
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Follow up: I have the parts.
    Does ANYONE know how to remove the rear cover?
    I loosened two flathead screws from the back but none of the back housing is budging. Removing the back cover is apparently how I access a large slot for me to secure with a flathead during shaft seal removal. Again this is the Power FLo Matrix which also has a weird motor housing (the motor is completely encased in a plastic shell) allowing the pump to "rotate" 90 degrees. Thanks.
    Remove the Hayward sticker to see what's under there.
    Support the site
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Scraped the sticker off - nothing but flat black plastic.
    Additional detail. Pump model is SP5615 - little to nothing about it on the Internet.
    These are the instructions I'm using but they get vague at the "remove the back" part.
    http://www.hayward-pool.ca/pdf/manuals/Matrix%2005.pdf
    Don't know. I haven't seen that before.
    Support the site
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Bubbling up to see if anyone has some thoughts on this? Just trying to get this goofy back cover off.
    If I can get time during work tomorrow it appears I can call Hayward too.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Back of replacement impeller rubbing against housing - safe to use?
    Got everything took apart and am putting back together. Closing this thread and starting a new one to ask about a new issue.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    A post-mortem to this thread:
    <rant>
    Cut to the chase: If you happen to have this pump (SP5615) do NOT order SPX1500L or SPX1500F as an impeller replacement. Yes, it is a Power-Flo Matrix. No it is not the American version (even though it was bought from a company out of Buffalo, NY).
    It requires the SPX1591F (just like the picture at top of this thread). This is a Canadian-sourced item. The stem is at least .5" longer than the SPX1500x impellers. It took me a while to locate this. You will have to order this from Canada online shop that has a "no returns on parts" policy and it will be a little pricey but...
    Again despite what some may say SPX1500x are not identical replacements for SPX1591F impellers (why would they be?). Also, do not be surprised if Hayward and the reseller tell you this impeller is not compatible with the pump.
    </rant>
