Results 1 to 7 of 7
Thread: pool finish choice
    Jan 2016
    Wayne New Jersey
    17
    pool finish choice
    Can someone help me choose between Pebble Fina and Hydrazzo I like the smooth finish of Hydrazzo but from what I read I like the quartz finish of Pebble Fina
    My question is is Pebble Fina as smooth as the Hydrazzo. I will be retiling and new plaster in about three weeks and I have to make a choice ?
    45,000 gal gunite
    with spa
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Re: pool finish choice
    I've never heard of Hydrazzo before. It's difficult to compare, lots of companies all have their own types of Pebble-whatever now. You would probably need someone from your area, who knows that particular version.
    Apr 2013
    Sacramento, CA
    2,769
    Pebble tec has Pebble sheen which has a plaster feel. My Pebble Fina is great.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Ive heard of and seen pics of hydrazzo, Its a gorgous plaster. Unfortuntely, I have never seen or felt it in person, so can't compare the feel of it to anything else.
    There are a couple of TFPers here who do have hydrazzo, and hopefully they will see your thread and chime in.it
    Divin Dave,
    Aug 2014
    Houston tx
    2,524
    Maybe ask your PB to show you pools of each so you can check them out yourself.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Conman View Post
    Hydrazzo is an ultimate finish and smooth as it gets. It's a sanded/polished finish, and you have to go with tile to get smoother than this type of finish. There are others like it, but some of the colors offered are in a league of their own. Lots of options with that with some really wild choices. Much of it looks just like the old Terazzo flooring from decades ago, hence the name. Fabulous stuff, but out of my price range. If you want the smoothest, this is the way to go.
    Essential Links:
    Jan 2015
    las vegas
    92
    Hydrazzo is sanded/polished like mentioned above, not quickly buffed like some other products. This process usually takes about 4-6 hours (with 2 polishers) for an average size pool, and results in a super smooth finish. While quartz pools can have the same procedure done with similar results it is required by manufacturer.
