Thread: Prologic PLPS4 or PLPS8
    Jan 2016
    Houston
    63
    Does anyone owned a Prologic PLPS4 or PLPS8? If you do, can you please give me a picture of the inside of the panel so I can study how to wire my stuff up once I have the money to buy a controller?
    Thanks
    My Pool Information :
    - Plaster Inground Pool - -Pool size about 13500 gallons
    4 Hayward Pumps : Filter, SPA, Waterfall, & Cleaner :
    Hayward 48 DE. Heater -Hayward 400 IDL. Chlorine Feeder -
    Polaris 280
    Jan 2016
    Houston
    63
    Re: Prologic PLPS4 or PLPS8
    According to the manual, The connection at the main house panel should be to a 240VAC circuit breaker rated at 100A maximum.
    I am going to have an existing 40A breaker main house connections that feed PLPS8 main powers. Can someone confirm my 40A breaker would be fine?
    Polaris 280
    Apr 2013
    Sacramento, CA
    2,769
    It would be best if you could keep the same project in one thread. Otherwise we go nuts and get lost.
    Can you install a PLPS8 control center on a 40 Amp 240 breaker? Yes. Will it work for you? I don't know. With 4 pumps you need to do some math and also take into account the other loads.
    38,242
    All the manuals are available for download from the Hayward website.
