Results 1 to 10 of 10
Thread: PoolMath, and Where to start?
    Mar 2016
    Leonard, Tx
    5
    I love the PoolMath Calculator as well. The only thing I really struggle with in being new to this is which level to adjust first and how long to wait in between adding different chemicals. Anywhere on here I might find that?
    24x52 Pro Series Ultra Frame Pool; Intex Krystal Clear Sand Filter Pump, 2100 GPH Pump Flow Rate, 110-120V with GFCI; Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PoolMath, and Where to start?
    Welcome to TFP,
    The best place to start is with the ABCs in Pool School, and working your way through the other basics there. For specific help from the forum, can you post some test numbers for us to look at and offer some advice?
    Essential Links:
    Jun 2014
    15,008
    Welcome to TFP! After you've hit those pages, if you still have questions, please let us know. It can seem overwhelming at first, but once you're past the initial info, you'll be surprised how easy TFP care really is.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    What you work on first depends on your readings. If you have astronomical CH or CYA readings that would indicate a partial drain is in order, deal with the drain first. There's no point in treating water you're just going to dump out anyway.
    If those numbers are low to normal, then typically you adjust pH first because bleach works better at the proper pH and if you're looking at a SLAM to kill algae, you won't be able to test pH for a while due to high FC interference.
    Best bet is to post the results, as Patrick stated above, and someone will be along to advise you. It'll make more sense once you start doing and testing and seeing results.
    Mar 2016
    Leonard, Tx
    5
    I have actually spent a lot of the last two days reading through everything on Pool School. I do not have any of the recommended test kits yet. Honestly not certain exactly which one I have. Its leftover from last year. But not strips. We had this pool last year with the pump it came with which is pretty much useless and the pool turned into a green mess. At any rate, we drained the pool and cleaned it a few days ago and refilled it. We also added a new pump and the saltwater system. We have added the recommended amount of salt but that is it so far. The readings I have right now are: CYA - 0, FC - 0, PH - 8.2, TA - 132. Not sure which one to tackle first and the timing of it all.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Get some bleach in it. Then go look at your test kit or take and share a picture of it.
    Where did you store the test kit?
    Kim
    Jan 2014
    Buckeye AZ
    807
    If you let it sit like that you will have algae in no time. You should get chlorine in as soon as possible; the SWG is good for maintaining, but not quickly getting up to proper levels. For that reason I'd suggest using liquid stabilizer to get your CYA level up to 30 to start off. There are some products that combine CYA and chlorine (like shock products) but that can get tricky, so just go separate.
    Liquid stabilizer is more expensive, but if you wait for granules to dissolve over a day or two, you will have to wait to get the chlorine to hold in the pool, and you risk algae.
    So IMO: Use pool math to add the proper amounts of:
    Liquid stabilizer - to get from 0 to 30
    liquid chlorine (bleach) to get the FC level up to 4.
    acid to get your pH in the mid 7s.
    You will need to get a recommended test kit, and from there start getting your CYA level up to the 60s or 70s, and dial in your SWG to keep the proper level of FC in the pool.
    Everything is covered in Pool School and Pool Math, tabs at the top of any page.
    edit: I would spend a few days at a CYA of 30 and a FC of 4, to make sure you don't have an algae bloom, before adding the rest of the CYA to get up to 60 or so. Killing the algae is much less laborious at that lower CYA level.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mar 2016
    Leonard, Tx
    5
    The test kit was stored inside the house in a cabinet.
    Mar 2016
    Leonard, Tx
    5
    Quote Originally Posted by BuckeyeChris View Post
    Thank you for the helpful information! I have read through all of that but was unsure of what exactly to tackle first. Let me see where I can get with all of this. At least we have more daylight hours to mess with it when I get off of work in the evenings now
    Jan 2014
    Buckeye AZ
    807
    you can certainly use the less expensive granular CYA to get from the 30 range up to the higher number recommended for SWG. No need to buy way more liquid stabilizer than you'll need at this point. Getting ANY in the pool right now is most important.
