Results 1 to 8 of 8
Thread: use of pool perfect recommend by leslies
    Mar 2016
    Santa Clarita,CA
    14
    Smile use of pool perfect recommend by leslies
    Hi, i am new to the site and need some assurance on NOT using pool perfect for phosphate control due to the high cost. I am going to get the taylor k2006 kit and keep up on the chlorine/cya levels and start using liquid chlorine as often as needed with testing often. Leslies has me me adding 2.5 capfuls twice a week, i can't afford that. What do you guys think?
    thanks, dave
    16x36 free form gunite, 8' deep end, raised spa attached, 18,000 Gallons, Stone Scape mini pebble, remodeled 8/10/2015, Pentair variable speed pump #011018, DE filter, Pentair Easy Touch upgrade automation w/ screen logic, Pentair 520549 Easy Touch indoor control panel, is4 spa side remote, Pentair Mini Max plus 400 heater, Hayward Navigator pool vac, IntelliBrite 5G color LED light in pool and spa
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: use of pool perfect recommend by leslies
    You do NOT need that stuff! Phosphates aren't a problem in a properly chlorinated pool.
    IF you had an algae filled pool the phosphates are food for algae, but we don't advocate letting algae take hold so.... no need to worry about phosphates! LOL
    Walk out and stay out of pool stores and your pool will be much healthier and cheaper to maintain by using our methods.
    Good call on getting that test kit as it will save you bundles of money in the long run. I promise!
    Jun 2014
    15,008
    EXACTLY how we all used to feel.
    Aug 2014
    Shallotte, NC
    693
    I'd divide your question into two parts:
    1) Do I need Pool Perfect? No, you don't. As far as I can tell, it will do nothing for you.
    2) Do I need Phosfree*, phosphate remover? If you test your water and conclude, on the basis of those tests, that reduction of phosphates is in order, perhaps. "A properly sanitized pool" implies a pool that never drops below the minimum required free chlorine. Apparently, from the amount of "algae complaints" we hear, there are a lot of pools that drop below that minimum number and Mother Nature's punishment ensues. Algae feeds on phosphates and starving them can't hurt, if you are prone to letting your FC drop below the minimum.
    So, I conclude that if you have a regime of testing for FC and never let the chlorine drop, you probably don't ever need to worry about phosphates. If that isn't the case, you may want to read further and develop an iron clad regime of testing and response before buying "stuff" from the pool store.
    FWIW, I use borates and check for phosphates. Maybe not necessary, but with proper testing and judicious use, they are cheap insurance against that unanticipated algae bloom.....
    PS*
    No personal recommendation to buy the Phosfree brand, other similar chemicals can be bought at significant discount.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    If it means anything, I've never had my phosphates tested. I've never added Phos-free. I've also never had an algae bloom in over 5 years. And like you, I don't ever really close; it just gets too cold to swim in and too expensive to heat.
    If you locate a HASA dealer nearby, you can buy a whole lot of refillable jugs of 12.5% bleach for the price of a jug of Phos-free.
    Dec 2015
    arlington, tx
    100
    Quote Originally Posted by ewkearns View Post
    2) Do I need Phosfree, phosphate remover? If you test your water and conclude, on the basis of those tests, that reduction of phosphates is in order, perhaps. "A properly sanitized pool" implies a pool that never drops below the minimum required free chlorine. Apparently, from the amount of "algae complaints" we hear, there are a lot of pools that drop below that minimum number and Mother Nature's punishment ensues. Algae feeds on phosphates and starving them can't hurt, if you are prone to letting your FC drop below the minimum.
    agree
    Mar 2016
    Santa Clarita,CA
    14
    thanks for the help
    Dec 2015
    arlington, tx
    100
    Welcome!
    thanks for the link richard.
