Thread: Considering Using Sider Crete Pool Finish Coating
    Mar 2016
    Alexandria/KY
    4
    Wondering if anyone can provide some insight on this product I am considering. I bought a home with a concrete pool and the marcite coating is rough in texture causing the kids feet to literally bleed after a day of swimming. The texture also allows algae to grab hold making it difficult to clean. The bond on marcite looks good but I will sound check when I drain pool.
    Nov 2011
    Moberly,MO
    1,010
    Re: Considering Using Sider Crete Pool Finish Coating
    Look into ecoFinish. It is a thermal plastic finish and is a longterm fix
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Mar 2016
    Alexandria/KY
    4
    Thanks! I'll look it up
    Mar 2016
    Alexandria/KY
    4
    Doesn't look like something I can tackle as a DIY project when seeing the torch application sprayer. Nearest installer of product 109 miles away
    Oct 2011
    Plantation Fl
    69
    Did you use the product?
    9K 13X19 inground plaster pool. Pentair IntelliFlo 011018 Pump, Pentair Clean and Clear 150 Cartridge Filter, Hayward Aqua Solar GL 235 Controller, Zodiac MX8 pool cleaner, H2Flo FlowVis Flow meter, 4 4x12 rack mounted solar panels. South Florida pool facing North inside a screen enclosure
