Results 1 to 12 of 12
Thread: Star floor installed
    Sep 2015
    Orlando, FL
    33
    I installed my fiber optic star floor kit, and cemented them down per instructions. Marcite is going in tomorrow, trying to figure out how/when to trim them flush with the surface.
    Instructions say to "trim when plaster is dry", but these clear plastic rods are tough to cut. Hot knife isn't effective, thinking using a tile cutter or similar.
    More importantly is the timing. Putting in a pebble finish, but filling happens immediately. At least these lights are on my shelf only, but can the finish be walked on for getting around to the lights?
    Maybe let the finish cure, then drain below the shelf and trim?
    I'll post a pic up shortly.
    Any ideas?
    Sep 2015
    Orlando, FL
    33
    Re: Star floor installed
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,627
    No ideas but can't wait to see them in action!
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Use a Dremel tool or Die Grinder to cut them to length when your finish is cured. I like the idea of draining after that happens. Not sure I'm right, but it's the first thing that comes to mind. Never answered this question before either, so this must be something pretty new.
    Essential Links:
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    wow that's really neat! please post dusk and night photos when it's all done and working.
    Dolphin E10 Cleaning Robot.
    Dec 2015
    Chattanooga, TN
    38
    I'm considering this too and surely would like to see some finished pictures! How did you resolve your installation questions?
    25 x 60 IG, 10' sunshelf, 24' sh, 26' dp; 57,600 gallons; 8' Jump Board; Hayward Equipment: 2 Sand Filters 36" Tank S360T2; 2 TriStar 5.0 HP FR Pumps SP3250EE; 2 Natural Gas Heaters H400FDN; OmniLogic; Sense & Dispense HL-CHEM; 2 SWG; pH Dispense Acid Feed System AQL-CHEM4-ACID; 2 systems work independently; Hydrazzo Plaster; TigerShark 2 Plus Commercial Robotic; 1 Spa and 3 ColorLogic lights; CoverStar automatic cover.
    ellsian's Avatar
    Jun 2014
    Peoria, AZ
    216
    Oh wow, I had to look up what a star floor was!
    Amazing! Please post pics of your finished one
    Swim ready :) My Pool Build Thread. IG shotcrete 34x16 Grecian shape. 22k gallons. 3'6 - 8'6 deep. 12x5 Baja ledge w/ 2 Bubblers, 14' raised beam sheer descent waterfall in stacked rock. Custom stone diving board. Hayward sand filter, VS pump, Aquarite T-15 SWCG. A&A In floor system w/ Gamma 4 venturi heads, Blue surf Pebble sheen, Colorlogic LED. Future Travertine Sandcastle Owner.
    Jul 2015
    Long Island City, NY
    70
    Angle grinder with diamond blade for cutting porcelain tiles. Should take a few seconds to cut through and will leave smooth finish.
    Might want to discuss with your plaster sub. They could cut as they finish just prior to fill.
    Sep 2015
    Orlando, FL
    33
    Quote Originally Posted by BrownEyedSusan View Post
    So this project took a couple calls to the manufacturer, a lot of unproductive internet search time, and trial/error....but now that I'm done hopefully I can offer some suggestions.
    I did 75 lights (3 LED drivers, 25' fiberoptic lines) on a sunshelf. Usually these are placed on the deeper parts of the pool floor, and kits can come with much longer lines. The lines were pretty durable considering all the tugging and stepping on: jacketed and 2 fibers/light strand. The star consists of a base plate with the 2 fibers feeding into a vertical acrylic rod (partially hollow at bottom for fibers). The LED drivers live in a circular container meant for partial burial.
    Per the instructions, these lines were placed after gunite.
    Acid wash was prior to installing the lines. Portland cement was applied to protect the fibers and star hub (instructions). Marcite was done after, requiring hand troweling and repairing several lights in the process. Overall, its suprising more didn't break considering it was like a landmine zone. The shelf is 6' x 19'. 75 lights was way overkill, but I placed the 3 light zones evenly allocated to allow for future tweaking.
    Trimming took a couple experiments. The vertical riser is acrylic, and it charred with a hot knife or tile cutter. Best tool was my ridgid multi with a diamond blade, and final cut was with a dremel. Trimming needed to occur after plaster dried, because the vibration disturbed the finish. This didn't really delay filling, as they were only on the upper shelf. Might be an issue if on the bottom.
    Problems encountered: Even though I did 3 rounds of chipping away loose portland cement and cleaning up, the floor feels somewhat wavy (hand trowel) and actually a little hollow sounding in areas. Again, I think these are usually placed on the pool floor not where walking normally occurs. I expected a thicker marcite, but they know what they're doing.
    Hindsight I would have stuck these in the concrete during the end of the shell creation. The dowels always broke at the insertion base...and covering these with cement would have definitely avoided them snapping so easily. Alternatively, grinding out a spot for the lines and bases would've worked. Either of these would have avoided the uneven floor.
    The other issue was the mess of fiberoptic lines when the slack was pulled out of the shell. I ended up burying them in a plastic container, sealed but perforated bottom. Its possible to hotknife these fibers, but at that point I was over it.
    Overall, we like the lights...they're a neat feature. If I did it over again, I'd have done less lights or spread them out more into the pool. If anyone has any questions, feel free to ask.
    Jul 2012
    Tallahassee, FL
    30,627
    So pretty and different.............I hope they last forever!
    Kim
    Sep 2015
    Tucson, Arizona
    86
    Very cool. If 75 lights for your sunshelf is overkill, what density would you have preferred? From your other post, I assume your sunshelf is roughly 6x16 = 96 sq ft. 75 lights in that area does sound like a lot. Would 25 have been enough? Do you think 75 would have been enough for your entire pool, or would you have wanted to add more?
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    Sep 2015
    Orlando, FL
    33
    Quote Originally Posted by azdesertpool View Post
    I think 25-40 would have been fine. The luminance really depends on the active color/mode. Also, many are not overly visible unless you're looking directly down on them.
    16k gal, IG, marcite, 3HP VSP Ecostar, 2HP Booster 2speed, 200 sqft cartridge, SWG, Caretaker IFC, Omnilogic, Solar, Taylor K2006, Born 3/16
