Results 1 to 8 of 8
Thread: Salt Question
    Oct 2015
    San Diego, Ca.
    650
    Salt Question
    If there is NO Splash Out or Rain Flooding do you ever have to add salt to the pool?
    Thanks
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Re: Salt Question
    Nope! We have very little rain most seasons in Texas so very rarely does the rain get the water over the overfill and I have very little splash out and I rarely have to add salt. At most 2 bags a year.
    One time I did top off my pool, left it on for hours.....and it rained. Because it was raining I didn't go outside to check the pool. When I realized my mistake I was adding all sorts of chemicals including Salt to get everything in balance, and I had a large water bill. Now set my timer when I top off the pool!
    43 x 19 Gunite Pool w/ spa and fire pit, 19,000 gallons, Pebble Sheen Aqua Blue finish, Jandy 2 HP VS E-pump, Jandy 580 sq ft Cartridge Filter, Jandy LXI 400k Heater, Jandy Aquapure 1400 SWCG, 4 Jandy LED color lights, Aqualink PDA and Iaqualink, Polaris 280 with Booster Pump. Polaris 9550 Robot Cleaner. 1 HP Silencer Air Blower for Spa http://www.troublefreepool.com/threa...NAL-INSPECTION
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,762
    Re: Salt Question
    Quote Originally Posted by Philo View Post
    In this case, the salt level would likely rise from adding other chemicals. Acid is the chief offender of this, but nearly everything you add to your pool also adds salt (chloride) to some extent.
    Every gallon of acid added is the same as adding nearly 5 pounds of salt
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    AUSpool's Avatar
    Sep 2015
    Sunshine Coast, Australia.
    358
    Re: Salt Question
    You will need to replace what is being used by your SWCG but nothing due to dilution. From skylar18's experience and comparing pool sizes maybe 3 bags a year.
    Steve.
    30,000L (8,000g) Pebblecrete | Davey 3sp Eco pump | Poolrite sand filter & SWCG |
    Waterco solar panels & Astral E140 pump| K2006, BlueDevil pH, Salt meter & K1766 | Town water - pH 7.2, TA 50, CH 60 | Esky full of coldies |
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Re: Salt Question
    Quote Originally Posted by bdavis466 View Post
    I remember before I added my initial bags of salt after waiting the 30 days after plaster, My salt ppm was 1100 before I added my first bag of salt. I assumed it was mostly from the MA as I seemed to be dumping it in by the gallons (Probably exaggerating but it seemed like it at the time) to keep my PH in check and my bleach. I also found that there was salt in my fill water. I quickly stopped my pool builder from adding all the salt he wanted to by about a third....came in right at my target 3500 that I was aiming for.
    Jul 2014
    Sacramento, CA
    241
    Re: Salt Question
    Quote Originally Posted by AUSpool View Post
    My understanding is that the SWCG doesn't "use up" the salt -- it converts the chloride to chlorine, and as the chlorine is used in the pool turns back to chloride again. So any salt level decrease would be from splashout/draining, not the SWCG process.
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    skylar18's Avatar
    Apr 2013
    Austin, Texas
    299
    Re: Salt Question
    Quote Originally Posted by jmastron View Post
    That is my understanding as well, The compound that makes up salt gets split somehow when goes over the electrodes in the Salt Generator and one of the by products then is Cl. Somehow magically it goes back to Salt. Since I am not a chemist or that smart I could be wrong but that is my understanding. I am sure Chem Geek or these other chemists can explain.
    AUSpool's Avatar
    Sep 2015
    358
    Re: Salt Question
    I believe your right, I had never thought about it much and with all the rain we get we tend to add salt quite regularly so it's easy to assume it's being used. I was starting to think however that if we were using the chloride ion why doesn't a SWCG pool slowly become a solid block of sodium. A very small amount of chlorine gas is out gassed but Chem Geek explains in Pool Water Chemistry how it all happens.
    Steve.
