Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Should i bother treating algae months before opening?
    Mar 2016
    collinsville/ok
    8
    New pool owner here. I have an extremely green pool at the moment, and was wondering if I should bother treating it now, or should I just wait until opening and just start earlier. Is there any long term damage that I should be worried about? I checked the pH and it was about 7.2.
    17'x54", 7000gal Summer Escapes AG, Intex 3000gph 1hp pump, Intex 16" sand filter, Intex automatic pool cleaner, Taylor K-2006 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Should i bother treating algae months before opening?
    Welcome!
    I'd kill it now, if all the plumbing and everything is hooked up and the danger of freezing is over.
    If the water is cold, the algae won't reproduce very quickly, so when you kill a bunch of it, the survivors won't reproduce, so you'll kill it off faster now. Also, doing it now will beat the opening weekend bleach rush.... although if there are any sales on bleach, you'll be too early and miss them.
    Jun 2014
    15,175
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum Drew. I'd suggest doing it now as well. With that size of pool, I'd not be opposed to a fresh refill and then SLAM. It will go much faster if you do.
    Essential Links:
    Aug 2014
    Northern IL
    4,615
    I don't know much about the weather in your part of OK, but it seems that you aren't really months away from opening. We recommend opening when the water is getting to 60 degrees. I think your target opening should probably be earlier.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,539
    Quote Originally Posted by Texas Splash View Post
    Pat you are killing me with these! LOVE IT and all of them! Thanks for the laughs!
    Kim
    Mar 2016
    collinsville/ok
    8
    Thanks for the replies. The pool is draining now.
    My sand filter and pump will be here tomorrow. Is there any sense in running the pump without sand until the algae is all dead? Or just start filtering it out and backwashing, dead or alive?
    Jun 2014
    15,175
    Drew, I have to ask first ... why are you draining the pool? Or should I ask how much are you draining?
    Mar 2016
    collinsville/ok
    8
    Patrick B suggested a drain and refill to make the process go faster. I'll probably only drain it to 25% or so.
    I think I would rather the process go faster, and I think it's less than $50 to refill.
    Jun 2014
    15,175
    Oh, okay. Just wanted to make sure. Sometimes, depending upon the size of the pool, it is more efficient to do it that way. As for running the pump ..... once you top the water off you can run the pump to keep bleach circulating if you would like. Naturally you won't be able to filter-out any dead stuff, but it should help. If you have any questions when you start, please let us know. Oh, for some reason all of your signature info disappeared?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    In a pool this size, and with its filtering capabilities, everything that can be done to clean and drain before refill will be well worth the effort. It's simply no easy task to SLAM, and clean this up as compared to a regular pool with all the filtering capabilities. In this pool, filtering out dead Algae will happen, but at a much slower pace unless you have a vacuum rigged up.
    Essential Links:
    Mar 2016
    collinsville/ok
    8
    I was planning on waiting until I get the new pump and filter. The pump/filter should be here tomorrow, the auto vacuum today, and I picked up a vacuum brush head too. What else should I add to the filtering system?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not much to add that I can think of yet, just make sure you'll be able to hook up the vac hose.
    Oh, do you have the sand you'll need yet? You need #20 and guessing about 60 lbs or so.
    Essential Links:
    Mar 2016
    collinsville/ok
    8
    I bought 150 lbs of quikrete pool filter sand. The pump said 120 lbs, but I'll be able to use any extra for metalcasting.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, much more than I thought, so good deal. I had one a little smaller that didn't take near that. Sounds like you're good to go.
    Essential Links:
    Jul 2012
    Tallahassee, FL
    30,539
    Quote Originally Posted by DrewSmith007 View Post
    Not to be downer but did you already put the sand in????? We have seen MANY problems with that brand of pool sand. It had LOTS of trash in it and did a VERY poor job due to inconsistent sand size.
    If you cannot take it back or there is no other brand available make sure to back wash like mad and rinse VERY well.
    Kim
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I think the Quick Crete sand has been hit and miss hasn't it? I do remember some troubles, but I certainly could have missed the updates.
    Essential Links:
    Jul 2012
    Tallahassee, FL
    30,539
    The mess ups had been so bad that I would not be willing to chance it. The one poster that showed the Quik sand and the other brand was VERY telling. The trash and size difference was very telling. Of course I cannot find the tread now
    Kim
    Mar 2016
    collinsville/ok
    8
    I havn't even taken it out of my truck yet. I might take it back and get a longer vac pole.
    The research I saw seemed to have the problems when they didn't pour dry sand into water, but just straight into their dry empty filter.
    I'm not in any rush, my test kit won't be here for several days anyway.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by kimkats View Post
    Kim
    My findings on how not all sand is created equal
