Thread: Raypak R405A has a broken PVC connector? Can I use a union?
    When gutting out all of my old equipment I noticed that one of the 2" connectors that came with the heater that get glued to the 2" and then the threaded nut goes over is broke. Basically there is a chunk of the plastic that is just broken off. There is still about 1/2" intact which I would assume would be ok but I'm not sure.
    I wasn't sure if I should leave it be and see what happends, or if I could use a standard 2" PVC union to replace it with?
    Vince
    46k gallon vinyl, Intelliflo VF, Quad DE 100, Autopilot DIG60, Raypak R405a, Bravo Fury Auto Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Raypak R405A has a broken PVC connector? Can I use a union?
