Thread: Salt system vs Ozone?
    Mar 2016
    claremont,ca
    1
    Hello, I'm about to start construction on our new pool soon. I've been researching salt & ozone systems and would like to get some input on some veteran pool owners of both. I've read that you need to run ozone pumps a whole lot more... so confused and I have to make a decision soon. Please help.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Salt system vs Ozone?
    Welcome to TFP!!
    Salt is the way to go!!
    An ozone pool still needs chlorine for sanitation, so why bother?? Anyone who tells you you don't need chlorine does not understand the science or is lying to sell a product. Do a search here on ozone and you will get numerous threads regarding the systems.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Welcome!
    Go with the salt, if you're determined to have an automatic system. Ozone might be useful for a heavily-used indoor pool, like at a hotel or gym, but it's a waste of money otherwise. Use the search box in the upper right for Ozone and you'll find plenty, including some technical stuff by Chemgeek.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Run away from the ozone Now a Salt Water Generator is worth every penny, you will still need to run your pump but a VS or 2 speed pump can run on low and have enough speed to generate chlorine.
    We recommend at least 2 to 4 times the size of SWG, so if your pool is 20k gal you would get a 40k to 60k SWG. If you are automating stay with that same type equipment IE: Hayward SWG, pump, filter and automation or Pentair SWG, pump, filter and automation... it makes it easy in the long run because everything can communicate..
    Donldson's Avatar
    NW Ohio
    2,893
    Welcome to TFP!
    As was said, there is no Salt vs Ozone, ozone is only a supplemental oxidation, meaning it does not sanitize your water. In a private outdoor pool it is virtually no help as chlorine can more than keep up with the low bather load. As well natural sunlight breaks down any combined chlorine (the "chlorine smell" you often notice) that arise during use.
    Salt is a fine choice, but neither option are required to maintain a good pool. You can manually chlorinate and the results will be just fine. It would be a good idea for you to take a look at the Pool School tab at the top. Since you are in the construction phase you have some time to get a basic understanding of pool chemistry before you even start to fill it. Pool chemicals and salt systems and ozone systems, etc are all like race cars: no matter how good they are they will only work as well as the person behind the wheel can handle them.
    Hope all goes well with your build!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Isaac-1's Avatar
    SW Louisiana
    6,711
    People asking about Ozone here often get the opinion that we are against Ozone, we are not, Ozone has a place, but that is almost never in an outdoor residential pool, particularly not in a sunbelt state where you get plenty of free UV from sunlight to break down the combined chlorine products.
    So hot tub that spends its time covered = ozone good
    Therapy pool kept at near hot tub temperatures, particularly indoors = ozone good
    Maybe even outdoor high bather load pool (20+ people in the pool all day every day) = ozone good
    But none of these describe the typical residential pool, even if the kids have 3 or 4 friends over to swim 2 or 3 times a week and a big pool party 4 or 5 times per year (which is an EXTREME case), add to it your location in sunbelt state so just say no to Ozone, and don't even think about UV or a mineral system
    Ike
