Thread: EZ Touch change pump speed when heater come on
    Mar 2016
    Roswell
    1
    In my limited searching I cannot see how to program my EZ Touch to change the pump speed when the heater is on. I have a single intelliflo pump and I want to run the pump at low speed except when the heater comes on. The heater requires the higher flow rate. I think this is set via the F Circuits but not sure how. Does anyone know how to do this?
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,757
    Re: EZ Touch change pump speed when heater come on
    Welcome!
    Do you have a spa? If not then do the following:
    Set up a feature circuit and name it Pool Heat. Go to Settings> Circuit Names> Select an empty feature Circuit and name it Pool Heat, Return to the menu
    Go to Settings> Circuit Functions> Scroll to Pool Heat > Assign it to Heater, Return to the menu
    Got to Settings> Intelliflo> Select Pump #1 (only if if you have more than one pump)> Select Speeds> Scroll to Pool Heat > Select the desired RPM you'd like the pump to run.
    If you have a spa, then things will change a little bit. Can you also provide a little more info about the pool and equipment?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
