Thread: Question regarding wiring and timer for a 2 speed pump.
    May 2011
    Montgomery, TX
    176
    Right now I have an intelliflo hooked up to a manual timer. the booster pump is also connected to a manual timer. I'm getting quotes tomorrow to replace the broken intelliflo and go with a 2 speed pump. Will the timer have to be replaced? Will any other wiring have to be done? Thanks.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Question regarding wiring and timer for a 2 speed pump.
    An intelliflo has an internal timer so what does the manual timer do? In short I am not understanding. You can use a Intermatic T106 timer for a pool 2 speed.
    This isn't exactly on point but its in there: How To Install a 2-Speed Motor and a T106 Timer - INYOPools.com
