Thread: How Long To Check Salt Level??
    Jan 2010
    Randleman,NC
    620
    Just started adding salt today.How long should I wait to check salt level.New System and New Water started today.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jun 2014
    15,239
    Re: How Long To Check Salt Level??
    It might take about 24 hours for the salt to completely dissolve, and perhaps another day or two to fully acclimate with your water as the pump mixes it all real good. But you can start testing in a day or so just out of curiosity to see how well you are doing. Keep in mind it may take a few days of trial and error as you find yourself adjusting pump/SWG run time and percentages for optimal FC output.
    Pool School - Water Balance for SWGs
    Pool School - Salt Water Chlorine Generators
    Jan 2010
    Randleman,NC
    620
    My installer told me to not plug in SWG till I get my salt level up.
    Jun 2014
    15,239
    That's true. Generally at least 24 hours. Of course you'll still have the pump running to mix it all. Once you feel confident you're showing good salt readings and turn it on, you'll find yourself testing and adjusting back & forth until you find what works for your pool based on size, equipment output, direct sunlight, etc.
    Since you have new water, watch your FC level (keep some bleach available as a back-up) and ensure you have CYA started for that minimal target of 70 ppm.
    Jan 2010
    Randleman,NC
    620
    Well,we are up and going.Noticing a little burn smell and box is warm in the upper part.Is this normal for a new start up?
    Sounds like the transformer is getting too hot. Maybe a warranty call is in order.
    Support the site
