Thread: Reliable SWG for 10k gal AG pool?
    Mar 2016
    Smithsburg
    2
    We've had Intex all vinyl pools for years. Now we are getting an AG pool that doesn't need to be put in the shed every fall. My pool (MGK pools- Lamark) has resin parts for just about everything, except stainless steel hardware, steel walls and an aluminum bottom track. We are getting a Reliant cartridge filter (1 h.p.)and some kind of salt water system. What type of SWG is more durable? They can save a lot of time (I like that!), but are costly & don't seem to last long (don't like that!)
    Rick
    21 ft. round, 10k gallon AG resin pool with steel walls & aluminum bottom track. Reliant 1 h.p. cartridge filter. Saltwater system. Hagerstown, Maryland
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Reliable SWG for 10k gal AG pool?
    Welcome to TFP and congrats on the new pool! Saltwater is definitely the way to go for ease and convenience.
    Are you looking for a permanent hard plumbed unit? The Hayward AQR9 is a good unit, Hayward AquaRite Chlorine Generator System AQR9 | Hayward AQR9
    Or this is good, Hayward Salt Swim Salt Chlorinator SAS-ABG
    The cheapest way to go is an Intex saltwater chlorine generator which should work for at least 3 years or so.
    Mar 2016
    Smithsburg
    2
    Thanks for the welcome to TFP. We are excited about the new pool & can hardly wait for warmer weather!
    I used an Intex saltwater chlorine generator on an intex easy set (100% all vinyl) pool for years and was very happy with it. I'd probably go with another Intex SWG for my new pool, except for one thing. Intex says the appropriate flow rate for their larger SWG is 700 to 3000 gph. My new cartridge pump (one speed) is 6000 gph. I emailed Intex to see if their SWG would work, but I haven't heard back from them. I have no idea what problem a "too high" flow rate could cause. What do you think?
    Rick
