Results 1 to 12 of 12
Thread: T-cell replacement
    Jun 2015
    Mandeville, LA
    7
    T-cell replacement
    Are T-cells interchangeable between Aqua Rite and Swimpure Plus?
    12k gal; IG gunite; 420 sf Pentair Clean & Clear Plus ctg filter; 2 hp Pentair pump; built c. 2007; test strips and pool store; Hayward Aqua Rite SWG
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: T-cell replacement
    Hi Marie,
    Welcome to TFP!
    Yes, the T Cells are interchangable.
    Divin Dave,
    Jun 2015
    Mandeville, LA
    7
    Thank you. That is good news. Now. I'll have to get more info and come back for advice about why the new t-cell isn't generating chlorine.
    Jan 2015
    Maritimes
    56
    Hi Marie, just curious, what size cell did you have and how many years did you get. I sure hope the builder didn't undersize it. That will greatly reduce its life.
    Jun 2015
    Mandeville, LA
    7
    There was a t-15 when we bought the house and it was beyond 4 years old. I replaced a few months ago with a t-15-step. All was good in the beginning and then started having issues with chlorine production. Because it was the winter, the issue took a backseat. In Louisiana, we are having steady days in the mid- to upper-70's. Time to get to the bottom of the problem. I noticed today that the panel is not reading the salt properly even after I tried resetting.
    Jun 2015
    Mandeville, LA
    7
    Not "step" t-15-swp
    Jan 2015
    Maritimes
    56
    I would price out a t-15 cell, with your volume of water it should last 4-8 years depending on how long your season is. They come with a three year warranty. One other thing is to ensure your cya is around 80 ppm, having proper cya will allow you to turn percentage down and lengthen the life of a cell. Improper readings are the first sign of it coming to the end of its life sadly.
    Jun 2015
    Mandeville, LA
    7
    The current cell is only a few months old. I may take advantage of the home warranty to have the panel checked.
    What are the diagnostic readings?
    Support the site
    Jun 2015
    Mandeville, LA
    7
    71
    17.6 (this number seemed like a moving target - not sure if I got it right)
    0.00
    40p
    -0
    AL-0
    r 1.55
    t-15
    Bad thermistor.
    Support the site
    Jun 2015
    Mandeville, LA
    7
    Thanks. I'll call the home warranty company.
