Thread: does power on off and pump on off damage the pump
    Jul 2012
    Whidbey Island, WA
    397
    good morning
    we have high wind watch today
    with conifers everywhere power outages are then the rule
    and often the power flickers on and off in seconds or minutes as the event unfolds
    if the pump is running on auto it then goes off on off on within seconds or minutes
    does can this off on off one damage the pump?
    should I best just turn it off while the wind blows?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    JoyfulNoise's Avatar
    May 2015
    13,175
    Re: does power on off and pump on off damage the pump
    Variable speed pumps are much more susceptible to electrical damage than single speed pumps. I think you'll be fine. I, personally, would just turn the pump off if you suspect a power surge. If you had a variable speed pump, I would suggest a whole-home surge protector (which gets wired into your electrical panel) but that's not really necessary for single speed or 2-speed pumps.
    Matt
    Jul 2012
    Whidbey Island, WA
    397
    got it, thank you
    but what about a power surge when the power is restored
    May 2015
    13,175
    Quote Originally Posted by engrav View Post
    got it, thank you
    I suppose if the start capacitor was on the verge of going then a power surge could send it over the edge but the pump motor itself is a big A/C inductive motor; those types of motors can usually handle a fairly large voltage spike without any damage to the windings or core. The VS pumps, on the other hand, have lots of on-board solid-state digital components in them that are very sensitive to voltage spikes so, even in those cases, it's the electronics that gets fried not the actual motor windings themselves.
    Matt
    Jul 2012
    Whidbey Island, WA
    397
    got it
    thank you
