Results 1 to 12 of 12
Thread: Conifer plastics staircase style ladder
    2kCougar's Avatar
    May 2015
    Albany, NY
    35
    I'm thinking of adding these steps: Attachment 45670 Did anyone not fill them with sand and just attach weights to them? With 60 lbs of sand and water, there would be no way for me to get them out of the pool by myself when it comes time to close.
    Also, would you buy them again? I have small children (one just started walking) and I'd like something for them to be able to sit on and get in and out easily.
    Thank you!
    24' Radiant metric semi-inground, Hayward S180T92S, 8/2015 install, TF-100
    Jan 2010
    Randleman,NC
    620
    Re: Conifer plastics staircase style ladder
    I had a set like this since 2003.They were great and the biggest problem I had was the old design.Problems with staying together. New design now.Don't think you will have any problems. I would not put the sand in the steps.Alot of ways to hang weights on them.Alot of DIY projects that people have done and works.Search on here and web for more info.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Jan 2010
    Randleman,NC
    620
    I ordered this step plus the add on step to.I like this one because you can adjust the pads on bottom to adjust to floor.The other you have to a have a good flat bottom
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I have the confer wedding cake style. I do have them filled with sand, and it takes two pretty strong people to get them out. It could be easily done if you had one person inside the pool, and one person outside the pool. But by the time i took the steps out the water was in the 60s. I may try to dump out some of the sand this year, and then use weights to counteract the sand i can get out. I would never seal up the holes though, just maybe get them out earlier, with someone in the pool.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by kplaster View Post
    Attachment 45674
    Sent from my XT1030 using Tapatalk
    this is the one I have, i sealed all the holes in it and attached 2 45 pounds weights to it... has worked great.... I took them to a place that does spray on bed liner and had them coated very thick, 8 months later and still no rust..
    you can just see them on the sides in this picture.
    Jan 2010
    Randleman,NC
    620
    How did you fasten them? I haven't put mine together yet.I like this.
    Jul 2013
    Fletcher, OK
    3,353
    you can barely see it between the stairs and side of pool.. all plastic bungee cord it goes over the step, through the holes in the weight, over the hand uprights and cliped in the back...
    You can kind of see it but it does not matter to me if its seen... it has been that way for 9 months ( don't tell anyone ) I never took the stairs out for winter and also did not put on a cover
    Just so you know, the 90 pounds of weight is right at just enough weight to keep it down and attaching it to the deck keeps it in place and does not move at all...
    here is a shot of the side, you can see kind of see how I ran it..
    Jan 2010
    Randleman,NC
    620
    Thank You.Definitely doing something different this go around.Hard getting them out when they are weighted down for sure
    Apr 2014
    FOUR cORNERS
    111
    I put mine in backwards, steps for entry and ladder that attaches I used for exit.
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    2kCougar's Avatar
    May 2015
    Albany, NY
    35
    Thanks for the tip on the adjustable feet. I think I'll go with this one instead.
    Jan 2010
    Randleman,NC
    620
    Haven't put mine together yet.But,that was one thing that sold me.Found the set on Amazon for just over $300.
