Results 1 to 8 of 8
Thread: Calcium Removal Question
    May 2014
    Las Vegas NV
    45
    I'm in the process of partially draining my pool and am noticing some calcium buildup on the tile. Can I just spray on the acid wash mixture, described in other posts, then rinse into the draining water?
    Thanks in advance!
    Any help appreciated.
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,424
    Re: Calcium Removal Question
    You sure can. You need to be aware it will lower your PH so you will need to be ready to push it back up when the pool is full.
    How are you testing your water? How does your fill water look on the tests?
    Kim
    30,403
    Not sure which "acid wash mixture" you are going to use? What is the concentration?
    May 2014
    Las Vegas NV
    45
    I was going to start at 5:1 as stated in other posts I've seen.
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    I've read 4:1 (water:MA) so your 5:1 would be fine. Make sure you protect yourself (gloves) if you're scrubbing the tiles by hand. If you come across particularly tough lumps you can use a razor blade gently on tile.
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    It is a little more work, but I discovered that Bartender's Friend is great at cleaning tile. Include the reduced hazard and it makes a little bit of elbow grease worth it.
    Mod note: Please see post below as a follow up on why this is not a good idea.
    20K IG, WetEdge technology lined pool, TF100 Test Kit, CircuPool RJ60+, StaRite pump, Hayward DE filter, Hayward Navigator pool vac. Zodiac MX8 vacuum thrown in garbage.
    Jul 2012
    Tallahassee, FL
    30,424
    But what will Bartender's Friend put in the water? I will ask someone and have them post if this is a good idea.
    Kim
    JoyfulNoise's Avatar
    May 2015
    13,177
    I would NOT want to use Bar Keeper's Friend (BKF) in my pool or in such a way that it can get into the pool. The active ingredient in BKF is oxalic acid (it also contains detergents and fine silica grit for polishing). Oxalic acid will help remove water stains, as well as iron stains, from metal surfaces (it works great on stainless steel pans), but oxalic acid is TOXIC upon ingestion. In high enough concentrations, it can cause organ failure, specifically kidney failure. Oxalic acid will form calcium oxalate crystals in your kidneys. Calcium oxalate crystals look like sharp spikes and cause physical damage to the kidneys. Calcium oxalate is the primary component of kidney stones and this is one reason why they are excruciating to pass when you develop them. Chlorine degrades oxalic acid into carbon dioxide, water and chloride ion, so it won't build up in your water but it will create some chlorine demand.
    Now, while scrubbing some tiles carefully with BKF is probably not going to add a harmful concentration of oxalic acid to your pool water, you have to ask yourself - why would I want to add something that is potentially harmful to the water when there is an alternative that works just fine, aka, muriatic acid. The answer is, you should not. So leave the BKF for what is was intended for (showers, sinks, pots & pans) and use something else in your pool.
    Matt
