Thread: CaliMar Titanium
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    CaliMar Titanium
    I am finally about to make the switch to a SWG. I'm looking at the CaliMar Titanium Edition Inground.
    Does anyone have any experience or knowledge about this brand??
    It's really inexpensive and has a 7yr warranty. Any thoughts?
    CaliMar Titanium Edition In-Ground Salt Chlorine Generator up to 45K Gal | CMARSCT45-7Y | Active Pool Supply
    Thanks!
    36000 Gallon, IG, biggest Hayward sand filter, vinyl liner, Polaris vacuum
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,189
    Re: CaliMar Titanium
    No information on that brand, but we recommend that you go 2X the volume of your pool. So, you should be looking at SWCGs in the 70K gallon range.
    When you buy a SWCG that is rated for the exact (or close) volume of your pool you are often required to run the pump longer than you might need to to give it time ot produce the amount of chlorine you need. Plus, you are probably going to need to run it at 100% most of the time. SWCGs have finite life. Being able to run it at 50% will double the life expectancy than if you ran it at 100% all the time.
    Support the site
    Tricia1969's Avatar
    Aug 2014
    North Alabama
    28
    Thanks!!!
    Jun 2011
    Long Beach, CA
    2,790
    It's another SWG that CompuPool is distributing. It you decide to go with that brand go for the 60 sized cell for your pool.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello, not sure what you went with, but Calimar Titanium Edition Salt Chlorine Generator is rebranded circupool rj-g with cpx power supply not 100% sure, but bigger heat sink. I can't recommend them currently.
